frist nitro boat
frist nitro boat
came across this for $200 new zealand $$$
800 long, 280 wide. 3.5 cc Rossi motor. and gear drive.
what do you think as a frist boat, i wanted to make 1 but dont have the stuff for it (right in the middle of moving houses) and i through this would be good to buy and do up, how fast do think it will go,
let me know what think
thanks johnnie
thanks johnnie
RE: frist nitro boat
Hi Johnny I have a friend here in NZ who has seen this boat and he says that it would need a lot of work to get up and running. Motor has had a rough time and gear drive is pretty worn. I was thinking of purchasing myself but instaed decided to purchase a new 1/12 Miss Elam Hydro through High Performance Models.
Hey there, Johnnie! I think it will go in the 30+ mph range. The $200 NZ Dollars converts to around $135 USD, so the price seems decent to me. If I were buying, I'd first try running as it is, but would most likely want to "Americanize" it with rear mounted strut and rudder... I'd keep the gear drive and lengthen the sub-surface stuffin' tube to get the prop behind the boat. Those older Rossi .21s are good engines. Should be fun!
cool, i see if i can ge a pic close up of the the gears
carimali do you know were i could get new gears from? have you seen the boat? the guy said that the engine feels good
thanks
thanks
ORIGINAL: CARIMALI
what about this one for $180NZ once again i know it will need somw work but that what i want to do, "do it up" also the other one that the same guy is selling, its got a CMB 3.5cc, needs alot more work by the looks $200NZ
Hi gasboatracer, not sure where you could get new gears from, could end up costing you a packet!. You would be better to see if you can arrange with buyer to have a look at either. As from experience with purchasing off Trade Me in NZ, never go off what the seller says. If you don't want to spend a lot of money then I would stay away from either.
Check out the Manukau Model Power Boat club web site forum, you can ask questions there and someone will get back to you. As you want to make sure that you can still readily get parts to fix either boat IN nz. As living in NZ can be a disadvantage at times when trying to get hold of parts....unlike the States where most things are readily available!!!
Purchased my RTR Miss Elam for $575, one of the better rtr kits I have purchased!. Since then I think High Performance Models in Whangaparoa have increased their price to $700. You could probably bring a kit in from Tower Hobbies for slightly less, but I did not want to have to wait.
I have purchased many an RC boat off Trade Me and in the end with the money I spent on them I could have bought several RTR kits.
i think i might buy the red one, but i need more input on the others thanks johnnie
it will be my frist rc nitro boat so yer
The copper plumbing needs to go along with the tuned pipe. The owner did a lot of patchwork just to the the exhaust out and messed it up as the way that it is is hurting performance. There are optimum lengths that the pipe has to be to work properly and it's way to long to be effective.
CA
ORIGINAL: gasboatracer
what work needs to done on the exhaust system?
This is a pic of a gas boat but same idea.
so the pipe should be where the yellow line is in the pic below? what about the green line could it go like that?
were that pretty much the reason why i might buy it, but also i dont think i will able to aford because looking at buying this ford XF fairmont
not buying a car any more so looks like it the nitro boat, i will buying the red one, now can any body tell me what i need to do to fix the exhaust system, pic would also be a help
thanks heaps
thanks heaps
KS
here is how My exhaust is run
Also the red one looks to be in the best shape to work with kinda neat lookin it needs a killer paint job to set it off no flames or graphics but something like a deep candy red with red or gold flake in the candy top it off with the name of the boat going down the side in gold leaf with a nice clear over it all, give it kinda an old school look..and if its not fast it will still look great!
