.18 TZ MARINE HEAD
Does anyone know if the head from a .18 os marine motor will fit on a .18 tz? I want to buy the tz for my rigger, but don't want it air cooled.
FL
I used the O.S. .18 marine head (black) on my TZ but found that in addition to opening up the bolt holes I also had to mill the underside of the head because the outer ring of the head bottomed out on the crankcase cooling fin before the head was seated on the sleeve. I took this area down even with the area that the shims seat on. It seems to work fine. The O.S. .18 engine has the top cooling fin lower than the top of the sleeve so there is no conflict.
