Exhaust Gasket
Some you've got to watch as not all engine blocks are made with the same width at the exhaust port. Most are but I have found the exception to the rule before. With the being spaced the same, it makes it easier for the aftermarket manufacturers to make them all the same.
ORIGINAL: unclecrash
How good does the copper permatex hold. Ive always liked the High heat orange or is it red
for cars and thermostats. Dave
MI
Wow that sounds like some good stuff. Thats what Im talkin full size cars with the orange or red high heat never used the copper before. Dave
im not sure if i would trust copper particles that close to the piston on a back breathing engine, i dont know if it would hurt or not. Try using brake quiet sealer...works good and peels off easy, cleans up with water and dries fast, high heat. I bought an empty squeeze bottle at the crafts store to run beads of it with. Works great, total control and width and no brush or paper towels needed if your careful. I've started using this on everything now. Rubs off better than anything, and stands up to fuel.
