First build question
FL
I'm building a mono and and using the speedmaster stinger strut and mounting the rudder on the right side. I need to know if it is ok if the rudder does not extend out as far as prop. or does it need to be at least even with prop? Thanks
If the rudder is in front of the prop, it's water deflection will interupt the flow of "clean" (undisturbed) water to the prop. It is best to have the leading edge of the rudder even with or behind the prop.
