cooling head ???
PA
Can you put a water cooling head on any engine? Like a .15 dynomite head on an .15 O.S engine. I'm thinking about up grading my 1/12 miss llumar boat. I think the bigest egine I can go is .18, but I want lots and lots of RPM. I want to go very fast. I only see a few egines with water cooling heads, any help would be great.
1 Post
you can buy cooling heads for lots of engines ,best place to look is where the engine was made if its os try the os marine engines the head should fit if its a .15 then a marine head that size should fit id have thought.what os is it you have? if its a plane motor it wont ever be fast in a boat they are low rpm you need either a marine motor or a buggy motor.both have higher rpm.
IL
There are a couple of people on here putting .21's in there 1/12 lumar/elam/bud boats, misshydro I know has one and one other guy for sure has one(his he mounted the engine on an angle). Look thru the forum you will find it, misshydro has all kindsa pictures and video's. If I'm not mistaken I think she said she was even gonna try putting a .28 in but i could be wrong.
Also I'm not sure but heads can cost some buck's I would make sure they are gonna work before buying (I have heard that alot of the heads are close and all that needed to be done was to open the bolt holes so it would match the casing) Good Luck !!!
Paul
Paul
theres a game i've played b4,an am still playing on old kyosho boat, guess thats why it's still on the shelf,the one sure fit i know is the k n b 3.5 will fit perfectly on a wasp 26 long as wasp head button is used.................may the force b with you ..
Is there a specific air-cooled engine you want to convert to water cooled? I installed an os cv-rm water-cooled head to the tz-tx 18. It no longer is a turbo head, but it now water cooled.
PA
ORIGINAL: sleepy306
IL
Ok if ya want ideas here is a link to a post about upgrading your boat to a .21 and a link to the video .
http://www.rcuniverse.com/forum/m_48..._1/key_/tm.htm
This is the video I will put both links one didnt work this time for me but it is a better quality video if it does work.
http://www.youtube.com/watch?v=fMhLTcWxeik
http://media.putfile.com/112-hydro
hope this gives ya some ideas, Thanks goto lastresort4x4 for the awesome boat !!!
Paul
Paul
PA
I looked all threw the post and I don't want that much work. A .21 is to much for me, is the O.S max .18 a good engine? 1.35 HP at 28,000.
ORIGINAL: sleepy306
It maybe of interest to comerford to as the pullstart version of the CVR m is $170 which is expensive compared to the non pullstart version which is $85! big difference! The CVR marine head is $20 or so so you could buy a TZ, a marine head and it would still cost less than the CVR and have another .5 hp, thats a big difference in a little motor! Also you could sell the TZ cooling head on ebay and recover the cost of the marine head
The only other thing is that it is a rear exhaust, so you would have to check for clearence and find the right shaped header.
Beno
ORIGINAL: cyclesoul
any chance of a little more info on this sleepy????
Im very interested to know what was required to make it fit. Since the TZ is more powerful than most .21 engines and is $60 off at tower at the moment at $140 i just had to buy one!
Beno
ORIGINAL: sleepy306
Beno
The TZ come with either rotary or slide carbs, just depends on which model number you order, no modding required there. You can get the TZ as a non pullstart as well, though i dont know if that one is on special too, though it may well be.
I like pull starts as they are one less thing to worry about charging! With my truck I used to hate carrying around the roto starter and its charger, plus having it die on me, switch crap out lose the shaft etc. I know thats not as much of a problem with a boat starter, i just like to have as little gear as possible, tuck the boat under my arm, grab my radio and go! As for blisters, if your pulling the thing over long enough to get one, somethings wrong! I know, Ive got one on my finger right now cause i had the engine to rich to start. Once the engine is dialed it doesnt take more than 5-10 pulls to get it going, if it does start checking out stuff (thats a mental note to myself!!!
One ways can last a long time if they are maintained and used properly. In the end it comes down to personal preference i guess
for sure the CVR is the easiest and most cost effective bolt in repower, but sometimes we want more, and an increase in horsepower of nearly 40% is hard to duplicate for the dollar difference. Im not sure what effect in changing from a turbo head to a normal head will have on performance though, if any. Isnt a turbo head just different to take a turbo plug? I dont think there is any radical shape or design that makes it that much more effective, How much difference will having a turbo plug make? cant be that much!
Ben
Ben
KS
LOL good ol RCU...funny thing here.....I never uploaded any files yet there are 4 up there you cant see them but I can Who has a small electric green and white and yellow plane with lights on the wings....I cant even delete them! its about the size of your hand
Hi Mike LMAO hey what pics were you trying to post they didnt show up. All thats there is click to see full size image. HMMM wonder who that could be. SMH Ahhh I think I know. LOL Hey what kind of crap are you trying to pull heading for the other side[X(]
KS
Roto starts have issues, pull starts are ok to a point, belt starts are the best once your set-up with one youll love it...And a turbo head makes a difference,,,In your wallet when you go to buy plugs for it
Nope cant see no pics but I can see where its says click on the image to inlarge. I think rcu has bugs. This morning it crashed and I couldnt get online message said they had a problem error or something. When I click on the spot that says inlarge image a page comes up saying it cant be displayed.
I hope this works, but here are some pics of my os18 tztx with the cvrm 18 cooling head. First off, the header should have some type of cooling. My header is associated 'factory' part that use to be blue, but not anymore due to the heat. The heat also melted some of the pullstart handle and pull start case.
I shaved off the area between the head button and the case since with the tz, the sleeve is almost flush with the engine case. In order for the button to have better contact with the sleeve, I shaved of the extra metal between the head button and the case. In the picture, I pointed to the area that I shaved almost all the way down. I also used longer head screws...the screw heads were larger than stock, so I had to open the are on the black part where the screw comes down in the head so it can seat properly. I didn't what the screws sticking out on top. At the end, the head screws were flush with the top.
this is what I did. Hope this can give others an idea of what you should or should not do.
