Trim Tabs
In short, they would have absolutely no positive effect. You have to remember that the mounting location would be the boat's transom. In the case af all properly running hydros, the transom is above the water and not in it. Since the transom area is supported by the prop and, in the case of the Vegas, stabilized by the rear wing, trim tabs would be just added weight in an area that would be detrimental to the boats performance.
IL
If your boat is chinning or lifting out of the water then I would guess you have your prop angle wrong, I haven't seen any hydros with trim tabs. I believe a hydro is meant to have most of the boat out of the water, so the trim tabs wouldn't really help. This is just my opinion some others here will have more practical experience.
Paul
Paul
