prop for 7.5cc k&b outboard
RE: prop for 7.5cc k&b outboard
ORIGINAL: eas___1990
alright i was just wandering if any of you guys knew what size carbon fibre prop works best on these engines
JD
GA
As jerry said, X447 is a good prop to start with, let you find the needle and set-up fairly easily. After that you can try X450, 1450, H-7, P230, P225 pitched up, P235 reduced,...... lots of props will work with that motor, assuming its on a tunnel?
~James
www.ovalexpressracing.com
~James
I have two K&B 7,5 cc outboard. I use P235 prop on a DeepVee fibreglass hull 40".
However, anyone know where I can get spareparts for this engine?
