octura prop queery?
octura prop queery?
i got my first octura prop today and it is not what i expected, the finish of the prop i got looks nothing like what i have seen here or any where on the net. the props i have seen look really rough, dull, and have plenty of meat on them, the one i got is really thin smooth and kind of sharp. is this just how they are or what? and does this prop need balancing, sharpening, and polishing?
cheers
the first pic is what i expected, and the second pic is what i got
cheers
TX
RE: octura prop queery?
You can guy props that are already sharpened and balanced...but it would have cost you 25-35 dollars. If you paid about 10-12 then it is a raw prop and needs to be balanced and sharpened.
The prop on the right looks like it is an aluminum prop. I have never messed with one of those...
Sean
Sean
If it's an Octura, it's aluminum. If you go to this site: http://www.pirespreto.com/newversion..._catalog3.html , You'll see that thye do make a few of them in alumnium. Plastic props aren't advised for any nitro boat and certain Fast Electric classes won't allow them at all.
Yes, that is the way that they come out of the package. The ones that you see have been sharpened, balanced and polished.
Octura makes two types, bronze or aluminum. Prather was the only other common brand that made stainless but they are out of production.
Octura does not use a seperate part number system for its aluminum and bronze. The package has check boxes as to what type of material it is made of, or specified what type you want when they are ordered.
The same part number could be either plastic, aluminum or bronze - only the stock price tells you the difference, along with the clear packaging and label marking.
Balance is more important than sharpening, but if that prop came straight out of the package it will have to be checked for balance, and the sharpening is what happens when you're working on its balance.
I use a Top Flight Magnetic Balancer, they are about 20 dollars and work very well, but there are also finger-style balancers where it is a small shaft stub you hold between your fingers, or use a stand of two utility knife razor blades to set it on.
Just a little bit of off-balance is greatly felt when you start your motor, and can trash a set of strut bushings in short order, and potentially be hazardous.
ORIGINAL: hyper701
here is the pkt it came in
I have never seriously looked at any of Octura's aluminum props in any hobby shops (mainly because very few users of them), but I don't think there should be any smoothing or sharpening done to them. They are cast from the same molds as the copper props are...they should carry the same parting line bumps and flash as those.
The ones I saw wernt marked on the outer pack that you posted. There was another piece of paper stapled under that one That said ele. only. I could check with my friend who works at the LHS tomorrow and see if your part number is the same as the ones he has on the wall if you want me to.
dam that sux ass, it was a ebay transaction, and it does say power source: electric, **** i must have missed thet bit. what will happen if i run it on my nitro aqua jet?
I dont Know what might happen dont want to speculate. I dont think I would run it though. Maybe others will chime in on this. I know alum. is a lot softer than the berylium copper.
The thing about plastic props is they are allowed to flex a little. Aluminum doesn't flex...it bends and stays there and gets worse once it starts to go.
You're dealing with a small motor, and I have heard that some of the guys using electrics running aluminum props are strong enough to be compared to running a 21 size engine.
I would use caution and good judgement on exactly how much thinning went on with that prop.....
Aluminum props are rejected mostly because they can't hold a feather edge when run. As soon as you get less than a couple paper thicknesses thin with aluminum, there is absolutely no strength left in the material and it just folds.
