What hull for a o.s 21mx engine.
RE: What hull for a o.s 21mx engine.
i had my Miss Vegas running with OS 21VZ-M, quite empressive, you'll see it's pics and vid in the miss vegas 2 thread make her better and faster by misshydro
Hi Guy a lots tunnel hulls are in the market,
Dumas Hot shot (wood kit or ABS)Tower
HTB 29 or 26 htbboats.com
Lynx 707speciaties
Leecrafts XTR21
Thunder Tiger Bandit
WOF 28/30 plans (RCboatmoder)
Woodstuff tunnel hull (hisa&her hobbies web site)
olds used hulls:
TS1 i saw in ebay
Dumas Sprint in ebay
thunder tiger Falcon in ebay
I think the new Top Speed III is near to availability.
The more cheaper is TS2.
Good Luck
Lynx 707speciaties
Leecrafts XTR21
olds used hulls:
TS1 i saw in ebay
Good Luck
My Feedback: (12)
SC
ORIGINAL: nitro Ahmed
My Feedback: (12)
SC
ORIGINAL: jrizo1
what hull can i get for a o.s 21mx engine other than the top speed?
thank you.
thank you.
IN
can i delete my post loooooooooooooooooooooooooooooooooool
isaw ur vegas video with os xm .21 ob, that was screaming boat[sm=thumbup.gif]
jrizo1,
if ur planning to go racing try getting those boat mentioned above like htb, lynx etc. but if fun boat build the dumas hotshot kit, it's a lot of fun and has speed it goes hi 40's with ur stock os xm .21.
My Feedback: (12)
SC
ORIGINAL: misshydro
You can convert it over to inboard motor!![X(] That would be my choice if I'd had that motor!!!
NB, CANADA
Guy's and girls,
I don't normally take sides but I think there is a bit of confusion here.
the 21 VZ-M is an Inboard engine and the 21 XM is an Outboard engine.
Piper is right, there is no reason what so ever to convert outboard XM engine into an inboard.
the XM has 1.3 HP @ 25000 rpm and the VZ-M has 2.5 @ 33000
Dan.
Dan.
OH
Come on Chuck!! cant convert it over?! But if that motor is 25.000 rpms,then I would waste my time to converting over to inbord! Dan the VZ-M top RPMS is 40.000!![X(] Oh Chuck if that motor is 300 dollars I would get the thundertiger pro.21!!! for less then that!!and it has way more power then that motor!! 2.1hp top ends at 38.000rpms!![X(]
GA
Jrizo, we have the HTB 290 in stock. Its one of the best boats out there. (that is available)
You guys are kidding yourselves if you believe the hype with the engine numbers that manufacturers post.
~James
~James
well it's actualy OS-21 VZ-M inboard,wasn't paying attention when i made the post top rpm upto 40,000,,,,and i have this boat hooked up just for fun and fooling around with friends, i love speed. i'll race my friend's home made air boat with OS-91 engine, don't think i would stand a chance but it would be great fun, i'll have him in the turns
WI
ORIGINAL: misshydro
A hotshot or similar sized tunnel would be as fast with the XM as most vegas boats are with RG-M's or VZ-M's
My Feedback: (12)
SC
ORIGINAL: misshydro
WI
may I add: you usually get what you pay for (if it was so much better and cheaper, OS would not be in the market at all.)
