got my new boat
got my new boat
Well i picked up a shockwave 36 Yesterday.
Today im ganna buy some nitro and a glo plug and start her up.
Im ganna dry dock it in a tub o water.
Couple questions
What glo driver should i buy?
And will running it in a pool hurt it?
Couple questions
RE: got my new boat
Ok, first of all, if you run it in a tub, without it actually moving thru the water, youll overheat the engine because no water is going thru the cooling system.
Glow drivers....[link]http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=PDB[/link]
Grease...[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMPH8&P=ML[/link] or [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDR02&P=7[/link]
Also, NEVER rev the engine on the stand for very long, youll drop the rod I learned that the hard way.
RE: got my new boat
I would read [link]http://www.rcuniverse.com/forum/m_2353104/tm.htm[/link]. And also go thru and loctite anything that has threads into metal. Use the blue not the red.
RE: got my new boat
well i put the first tank thru i cant belive how fast it goes. all i did was let it idle and little revs.
Right when it ran out it reved really high is that normal?
Tomorrow to a pond maybe
RE: got my new boat
good cuz it scared the s*it outta me i pinched the fuel line as fast as i could.
And richen in its clockwise right? and lean it its counter right?
FL
RE: got my new boat
ORIGINAL: shcokwave36
RE: got my new boat
ok when i started it it wasent loud just when it ran out of gas is when it went high yes i was shaking lol. it started for like a min for each start
RE: got my new boat
Try not to0 run out of fuel!!!!!! the engine is leaning out and will cause catastrofic damage sooner or later. use a timer or count laps again do not run your boat till it runs out of fuel!!!!
