Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
ts2 with thunder tiger outboard help !!!!!!
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 09-02-2007, 02:02 AM
rogerp1
Default ts2 with thunder tiger outboard help !!!!!!
i have got a thunder tiger outboard that i wuold like to mount onto a ts2 hull !!
do i need to make any changes to the hull for example to i need to add a spacer or change the mount to fit this engine onto the ts2 ?
(the tt outboard has an adjustable mount built into/onto the outboard)
any help would be great
thanks
Old 09-02-2007, 06:57 AM
GRANT ED
GRANT ED's Avatar
Default RE: ts2 with thunder tiger outboard help !!!!!!
You will need to grind the top of the mount away and elongate the mount holes in the side to alow you to get the correct prop thrust. When you adjust the thrust angle you'll see what I mean.
Old 09-02-2007, 07:31 AM
rogerp1
yes i see what you mean
i would prefer not to cut the mount is there a different mout avaliable that i could use ?
