mounting tt.21 outboard on TS2 hull
1 Post
can anyone please give me some info on mounting a tt .21 outboard on to a ts2 hull
(i am trying to find out the correct hight to mount the engine onto the hull )
any help would be great
RE: mounting tt.21 outboard on TS2 hull
You will need to drill/tap new mounting holes in the transom plate for the TT. Position the lower unit on the transom so the c/l of the prop is about 1/8" above the bottom of the sponsons. Also, on the newer TS2 kits there was a wooden shim incluced for mounting the TT because the adjustable mount on the TT didn't provide sufficient positive prop thrust.
JD
JD
