Pro Boat's Formula
RE: Pro Boat's Formula
could some one email me at [email protected] on where to get that adjustible stur for proboats im not familar with putting miss vegas adjustible strut on and changing the tube for bigger flex tube. boat is brand new formula .18 want to do a couple easy upgrades thanks everyone.
OH
Do not get one form t*L racing you'll be sorry..Alot of guys had been riped off by them. I had to redo my cousnts formula. There struts have no bearings in them. I can hook you up with a adjustable strut bracket that bolts to your old factory strut area and would bolt wright up the the vegas strut setup. All you would need to get is the vegas adjustable strut and flex cable and redo your flex tube or part of it. Just PM me and I can give you all the info you want!! Oh there the same size flex tube,the vegas& proboat runs a .150 flex cables!!! I'd use a smaller tube 3/16 that the .150 fits inside that tube. I'd went smaller because I'd ditched that tefflon liner.Plus with a smaller tube it can move easyer to adjust the strut without flexing the boat bottom to much. I can tell you the easyest way to do this mod.
OH
just hold your horses. I'll be posting pics tomarrow. Making a different strut bracket to hold the strut. It cheap and easy to make your selfs!! Plus this set up is alittle different then my oberto. This setup it very easy to do.With out hacking up you boat,just alittle of the stock tube off I'll even go into setting up/convert the stait shalf Miss buds too.
#33
took the formula .18 out to a local lake but first removed all the head shims but one and got a prop built buy 4 you props wow does she ever move know. a good friend has the miss vegas and he only beats me buy about a boat lengh so they are pretty close in my eyes.[>:]new formula is no slouch [8D] wait till i lift the prop 4ml.thanks for the tips guys it sure helped.
