Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
Turn fin question
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Turn fin question
Old 10-11-2007, 08:44 AM
venom290
venom290's Avatar
Default Turn fin question
B.J 26, ran it without turn fins but not happy with handleing. I f I want to mostly make right turns, do I put on the right turn fin or the left. Will one fin affect straight away preformence? (pulling or twisting). Thank you
jeff
Old 10-11-2007, 01:31 PM
NITRO_VEEDRIVER
NITRO_VEEDRIVER's Avatar
Default RE: Turn fin question
switch to 2 fins. one on either side of transom.. that should help alot. here is a pic of how my fins are. mind you its not the bj....but fins will help alot
Old 10-11-2007, 03:31 PM
Ron Olson
Ron Olson's Avatar
Worth checking out: http://www.aeromarinerc.com/
Old 10-11-2007, 11:34 PM
venom290
venom290's Avatar
It has 2 fins stock. Took them off to reduce drag. gained a little speed. Also had an aftermarket drive. Not impressed by it. Put stock back on. I was just wanting to put one fin back on. Right for right turns?
thanks
venom
Old 10-12-2007, 09:10 AM
NITRO_VEEDRIVER
well ...i will just say this... whatever tickles ur fancy... i use both on mine and they work great. but if ya like doin circles. go nuts
Old 10-12-2007, 02:24 PM
Vertical3-D
My Feedback: (20)
Vertical3-D's Avatar
yeah put it on the right to turn right, since it's a cat and will ride kinda flat in the turns one is all it will need for either direction I would think, a good cat hull shouldnt need them, but because it has a steerable outdrive it needs at least one, monos that are used for sport will run two beacuse the hull rolls on its side in a turn thus lifting the outside fin out of the water, this is why monos that are raced have the rudder on the right, so it goes even deeper in the turn rater then lifting out...
Old 10-12-2007, 11:36 PM
venom290
venom290's Avatar
Ding ding ding. Thats the answer I was looking for. Figure I've got a few more weeks to play. Painter buddy of mine said if I strip it down this winter he would do it up for free. Just do do it, Thank you all.
venom
Old 10-12-2007, 11:41 PM
ryan_t888
ryan_t888's Avatar
Proboat has not yet learned how to design a cat that can turn, and also how to avoid steerable outdrives. I would use both fins, or the right fin for right turns only.
Ryan
Old 10-14-2007, 03:28 PM
wave waker
u can try by using bigger rudder to compensate the function of turn fin and replace the steerable drive, might be better handling just like tc31 set-up.
