Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
which one for an aquacraft hammer?
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
View Poll Results: A poll
o.s. .18 cvr-mx
42.86%
o.s. .21 rg-m
14.29%
ops .21
42.86%
Voters: 7. You may not vote on this poll
Old 11-10-2007, 06:27 PM
fastnitrofiberglass
fastnitrofiberglass's Avatar
Default which one for an aquacraft hammer?
Which one of these engines would deliver more speed out of my hammer.
link to .18 http://www.funrcboats.com/ProductInf...oductid=OS1611
link to o.s. .21 http://www.funrcboats.com/ProductInf...ductid=OS13630
link to ops .21 http://www.funrcboats.com/ProductInf...uctid=OPS88761
Old 11-10-2007, 06:32 PM
nothinbetr2do
Default RE: which one for an aquacraft hammer?
i'd say get the ops, it has more power and it has higher rpm's. so it should make the boat go the fastest
Old 11-10-2007, 06:41 PM
Dan S
Dan S's Avatar
Hammer hull is too small for a 21.
Dan.
Old 11-10-2007, 06:44 PM
nothinbetr2do
well i guess he'll have to rethink this better to find out now then after he spent some money[sm=teeth_smile.gif]
Old 11-10-2007, 07:53 PM
Vertical3-D
My Feedback: (20)
Vertical3-D's Avatar
I would think it could handle a .21 but the OPS engine is worth more then the boat so Id say the O.S. .21 would work well, a .21 isnt really a whole lot larger then a small block, may be a little overpowered but Id rather have more power then less...if not though go with an .18 and get it modded, maybe you could find a used aquacraft .18 for cheap, and I believe O.S. had a hand in that engine...
Old 11-10-2007, 08:24 PM
piper_chuck
My Feedback: (12)
piper_chuck's Avatar
ORIGINAL: fastnitrofiberglass
Of the three engines you're looking at, only the .18 is available.
Old 11-10-2007, 08:41 PM
fastnitrofiberglass
I will be getting the engine locally. And if i use a .21... 4 1x1 trim tabs and a 3 1/2 inch rudder plus a surface drive... It will work.
I hope...
Old 11-10-2007, 08:42 PM
fastnitrofiberglass
Oh yah and all of those engines are worth more than the stock ep boat it is now. The hardware will probably be worth more than it too.
Old 11-10-2007, 09:14 PM
Vertical3-D
My Feedback: (20)
ep? if its an electric one then Id say no go...the nitro will eat ABS...plus its about as rigid as a rubberband...
Old 11-11-2007, 03:15 AM
GRANT ED
GRANT ED's Avatar
I fitted an OS .18 to my hammer. I never got it much passed run in before I decided to retire the boat and pull the running gear for another project. The biggest problem I found was the standard header pipe does not fit.
IMO a .21 is a waste of time in a hammer.
Old 11-11-2007, 07:56 AM
fastnitrofiberglass
allot of people gave me the same response when i crammed this http://www.funrcboats.com/ProductInf...tid=OPS89001US
into this http://www.offshoreelectrics.com/pro...p?prod=delta41
Old 11-11-2007, 08:11 AM
fastnitrofiberglass
Ok i have a crazy idea but it might work p.s. the hull IS fiberglass. i was trhinking of putting two outriggers on the sides of this boat for added stability. oh and im running this on the dead flat brackish (salt and freshwater mixed) river a street away from my house no one boats on this section for it is too shallow i run my mod llumar out there it works swell so stability is not a huge issue .21 IT IS!!! well uhh... possibly BUT I THINK SO!!!!!!
f16man
Then why are you asking us mr. hotrod, ps. the hammer is a worthless piece of plastic.
Old 11-11-2007, 09:31 AM
Vertical3-D
My Feedback: (20)
the nitro hammer is fiberglass, which is a little better at least....I am seeing this going the way of my first nitro boat which was the nitro vee I modded and made a dun reliable boat out of it, but I was still chasing 30mph, when I look back on that if I had put the money tword something else it would have been better spent...I sold it and now have my youngblood 45 that does 50mph...although I want to get rid of that and get a hydro or tunnel to go even faster...
Old 11-11-2007, 09:41 AM
fastnitrofiberglass
I was thinking of using a nitro-vee or ex hull but i want fiberglass but i may have to compromise. Things right now suck i had to sell nearly 17/18 of all my rc stuff i hit a real financial hole... so this a really budgeted project. I now have a fiberglass hammer ep and an avenger cat with a .90 so i might just have to go with some other hull. any suggestions?
