exaust cooling
What are the advantages (if any) of putting discharge water from cooling systm INTO exhaust on a nitro engine. Does it quiet it down?
Already have a cooling coil on outside of header.I have a habit of running a little lean and or hot and it helps to keep connector hose from meltin.
venom
venom
To my understanding hotter exhaust gases flow quicker which equals to more power
However, in RC terms, maybe the water cooling is more to keep the engine cooler itself rather than the exhaust
MD
if your saying to plum it so the cooling discharge goes inside the exhaust and out the pipe, i don't think that would work. i might be wrong not to sure. but i don't think your motor would run right, if at all. if your looking to just quiet up your boat, you can get different pipes and or mufflers.
MD
ORIGINAL: KENT SEAL
What's up gamesbeer1? You live around the corner from me. How 'bout that! (Elkton, MD) Where do you run?
Ok, so no water INTO exaust.
How bout the cooling coil I put on the header. No ill effects that I can see, and does seem to keep coupler cool.
venom
venom
MD
ORIGINAL: venom290
venom
venom
MD
yup, thanks ron. i've got over 2 gallons with the same coupler. and if you guys want to do it, just get some frig ice maker copper tubing and some play ground grade sand. then i taped one end of the tubing to keep the sand from coming out. then fill the tubing with sand. then hold the tubing against the header(after you take it off) keeping it alittle long on the starting end. this will give you some thing to hold on to. and start bending. the sand will keep the tubing from kinking on you. after your done just make sure to get all the sand out, then cut to length and fit in the boat
One to remember is that as you are cooling the exhaust header, and thus the exhaust gases, then the pipe tuned length needs to be adjusted to compensate for the cooler exhaust gases to enable optimisation of power output from the motor.
If you have access to more comprehensive workshop facilities, a water jacket can be fabricated up around the header, effectively making it a twin wall pipe with water cooling on it. Obviously needs to be welded or silver soldered /brazed up to make it water tight.
I have been told that JB weld works, but am not vouching for that as I have not used it before.
Glenn
Glenn
IL
I smoked the coupler on my MV. I need to find a "good" replacement coupler. What size should I look for? Areo Trend has some "cream" coupler tubing,that is supposed to be about bullet proof,but I'm not sure what size to get, ID/OD? I ordered a Nitro SV27 cooling coil for the header,but need a new coupler too.Ron
Some guys are starting to use Teflon tubing instead of silicon, but it has to be heated with a torch to fit it, and spring clamps used after because the heat will loosen them up again, but last forever.
The water injection into the exhaust gasses was experimented with Mercury Marine in standard boat engines for a few years, and only netted a miniscule advantage.
