Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
strut depth on vages
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 01-06-2008, 03:10 AM
flip3d454
My Feedback: (35)
Default strut depth on vages
please help i dont have time to search through the 100 pages on the vages form. i am runnin a y 535 that came with it.
motot all broke in and running strong but wont really stay on step in a turn.
flip
Old 01-06-2008, 09:16 AM
007clint
007clint's Avatar
Default RE: strut depth on vages
ORIGINAL: flip3d454
flip
My experience is that the hulls vary somewhat which changes the optimum strut depth. Use the 'search this thread' function on the 'AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!' thread and you will get lots of great feed-back focused on your topic.
Old 01-06-2008, 10:09 AM
Sean Bowf
Sean Bowf's Avatar
Stock engine, 3/4 of an inch from the bottom of the hull to the center of the stuffing tube with a flat thrust angle.
As Clint said, hulls vary, so it is just a good starting point. Normally the engine speeds up in the turns...so they normally run better in the turns. Is yours bogging down, or cavitating (ventalating)? Is it a real Y535 (metal from octura), or the 535 stock plastic prop?? If it is the stock plastic prop, it is known to cavitate in the turns unless set deep.
Might be that your engine is not quite tuned right too.
Sean
Old 01-06-2008, 04:31 PM
flip3d454
My Feedback: (35)
no the motor is way rich.
and yes the stock prop. i dont have a debit/cretit card so what grim prop will work. they # there props different.
flip
Old 01-06-2008, 06:02 PM
Nickos
Grim racer 36x55 prop is the one you want. can't think of the aquacraft number for it. It is slightly easier for the AQ.18 to drive, than the metal y535, so you may find the tuning necessary to use it is a little more forgiving. What % nitro are u running at this stage?
Nick
