Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
 Props for AQ .18 motor >
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Old 06-21-2008, 04:59 AM
Default Props for AQ .18 motor
I am doing a towerhobbies purchase and need to buy some 3/16" props
I don't understand all those numbers and so on so can someone please recommend me the correct props?
The hull/boat is a deep V slightly larger/heavier than an SV27, but uses an SV27 motor and strut
Help is appreciated
Old 06-21-2008, 06:12 AM
jetpack's Avatar
Default RE: Props for AQ .18 motor
Check out the general boating column and theres a prop thread right at the top, and you can read up on what would work. There's charts that will help you decide.
I dont run .18 motors but I would guess a 437. 37 is the diameter, 37 millimeters.
I dont usually just tell people where to go to look, I try and give a solid answer, but with props its kind of a different story because really the only person to tell you what prop is exactly right all depends on the boat and the driver when your out driving it. Lots of variables in a boat to tell exactly which one is right, but there is a starting size. Thats one of the reasons there's so many of them, and why your overwhelmed by it.
I would try and measure what diameter came with it and try and match it and see if you need to go up or down with the pitch size first. Dont be concerned with "lifting props" and stay with the "submerged" type for now, thats what most RTR boats are setup to go with.
Old 06-22-2008, 10:09 AM
Ok...
So I read up a bit
And it seems a good prop is a Octura 440 and the Prather 215
I noticed Octura has X and M. What's this?
And, does prop size have to be matched to the boat, or the engine??
Old 06-22-2008, 11:08 AM
jetpack's Avatar
I run a 440 and a 215 on my .21 motor, and they are about the biggest diameter I would want to put on it, so I would go a bit smaller if its an .18.
The letter designation M and X describe the lifting characteristics, or the shape of the blades. It has an effect also. The X is a lifting prop, the M I am not sure of its a new style but I think some of the tounge of the blade is cut out from the X to let the engine get more RPM's.
Would you be able to measure the diameter of the stock prop? The .15 and .18 motors are whats in the Miss Vegas. Maybe check into that to see what props they are using for diameter to start with.
The prop is matched to the motor, and then to a lesser degree to the boat. Too big of prop will lug the motor, too small it will rev out too high.
Old 06-22-2008, 12:27 PM
Dan S's Avatar
Spetz,
here's a link to your question on X an M series for props.
http://www.rcuniverse.com/forum/m_7637375/tm.htm
Dan.
Old 06-22-2008, 03:30 PM
I measured the 3 props I have (but I've only ever run them on a .16 Kyosho motor)
The standard one is about 40mm. It worked best but the engine never really revved that hard + overall speed wasn't fast
The other one is a 50mm and with this one the engine couldn't rev at all + slow
And the other one was 38mm and with this the engine revved heaps but went nowhere
I don't know about pitch. THey seem to half roughly a 45 degree angle
Thanks Dan I'll read it up now
Problem is I see props are like $15-$20 minimum so I don't really feel like "testing"
Old 06-22-2008, 03:52 PM
Dan S's Avatar
unfortunately that is part of RC boating, wait until you get into gas boat....props are a lot more expensive.
Dan.
Old 06-22-2008, 04:35 PM
Well that's something to look forward to!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
