MACs header question. for .32 dynomite engine
WI
Hi all Does anyone know the part number from MAC's pipes of the header we would use on the dynamite .32, everyone says move the pressure fitting off the header and to the pipe. macs does make one that fits. and I would rather do it the right way its only 20 bucks or so.. Thanks all.
RE: MACs header question. for .32 dynomite engine
Hey jerj, I can't help but you might find your answer here.
Steve
http://www.macspro.com/default.asp
Steve
ORIGINAL: jerj
Save the trouble of trying to figure out which header fits the .32 and JB weld the stock pressure fitting hole....it'll hold.
The pressure fitting should go at the fat part of the pipe for a smoother pressure pulse to the fuel tank, in the header pipe the spent gasses are moving by the fitting to fast and tend to lean out the mixture at high rpms.
WI
Hey all the oem header is restrictive and the nipple area is all wielded an gobbed up which restricts exaust flow thats why I want to replace it. and the pressure fitting should be 1/4" before the highest ridge in the tuned pipe..per Mac's instructions. later
Measure your bolt hole spacing and give macs a call I'm sure they have something that will fit with little or no modification.
