Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
 Thunder Cat 31 >
Thunder Cat 31
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Thunder Cat 31
Old 07-06-2008, 11:44 PM
Default Thunder Cat 31
Hello, everyone!
I have a Pro Boat Thunder Cat 31. I have barely finihsed breaking-in. It runs pretty good.
But through the stuffing tube, quite a lot of water comes in the boat, even though I throughly lubricate the shaft with a high qulaity marine grease.
I tooked out the shaft and the teflon liner to examine, and I see that there is a bit of gap between the teflon liner and the flex shaft.
The diameter of the teflon liner is a little too big than that of the shaft, so that there is a bit of gap between the shaft and the liner, and water comes easily in the boat.
Should I replace the teflon liner and the shaft (they are still kind of new. I just have finished breaking-in.)?
Even though I replce them, still is there a gap between the shaft and liner?
Your answer will be greatly appreciated. Thank you very much for your attention.
Old 07-07-2008, 02:12 PM
nitronut911's Avatar
Default RE: Thunder Cat 31
i dont think that the water is coming in thru the liner. water cant travel up. the prop is lower than the engine, so i cant see that. i think the water you see coming in the boat is coming thru the two vents on the hatch. spray can somtimes come up in them. a little water in the boat wont hurt it. happens to me after every run. usually, the wavyer, the more water comes in.
Old 07-08-2008, 08:53 PM
I just bought the same boat.Do the auto bailers work well? Thanks
Old 07-08-2008, 11:48 PM
Ron Olson's Avatar
I'm not a fan of auto-bailers as after a short time things get clogged up in them and they won't work unless you get the ones that you can take apart to clean.
Old 07-08-2008, 11:58 PM
fun4ej's Avatar
ORIGINAL: Ron Olson
I agree....and in the event your boat ends up upside down, the autobailers will act as vents....could be disastrous if you don't have flotation in your boat.
Old 07-09-2008, 11:40 PM
Hello, gentlmen!
Thank you for your answers. I was doing camping for the last several days, and then, I came back home now, checking up this.
I almost covered up the vents on the hatch to prevent water's coming in, leaving a tiny space for air flow.
But still the same amount of the water comes in. I put my boat in my bathtub for 30 minutes, and I see that water comes in through the liner a drop by drop very slowly.
I thought water cannot come in through the liner with the same reason that "Nitornu 911" mentioned. But with the test in the bathtub, I think water comes through the liner.
Even though my boat is a new, should I replace the liner and the shaft or not?
Your help will be greatly appreciated. Thank you.
Old 07-18-2008, 05:57 PM
Can u take apart the thundercat ones?
Old 07-18-2008, 10:05 PM
here's what i did on my nitro hammer way back, i'm having problem with water coming up from stuffing tube so i drilled a small hole in the stuffing tube(look the dark spot on the pic),,it works though.
u can try it won'y hurt the boat...
ID:	993295   Click image for larger version
Old 07-18-2008, 11:50 PM
I've never had any trouble with autobailers, octura's are very easy to clean, just a ball held in place with a removable cotter pin. Just keep the inside of the boat clean and you shouldnt have anything cloging it up.
Old 07-22-2008, 09:58 PM
Do u have a thundercat at the time, cause i just orderd one and wanted to know how u liked it when it was stock?
Old 07-22-2008, 10:01 PM
[link=http://h1071118.hobbyshopnow.com/products/description.asp?prod=PRB2750]Thundercat 31[/link] Pretty sweet boat
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
