boat repair question?
I havw an old tunel hull, i think its made by mrp, its made of ABS, i took it apart with no problems, what kide of glue should i use to joint it back togather?
thanks
thanks
CA
RE: boat repair question?
ORIGINAL: misshydro
super glue/CA glue will work.
For ABS 'glue' you need 'Stabilit Express'.
There is a specific epoxy that MissHydro is refering to. It actually softens the plastic contact area to give a better bond. Basically almost melts the plastic together ensuring a tight and hard to break bond plastic to plastic.
ON, CANADA
ORIGINAL: bryston
thanks
thanks
Ryan
