.12 mono design and kits
I have designed a .12 mono that is much like the Wildthing12s that were made for a little while. The boat should run right with the SV27 nitro,.. probably better!
I have a PDF files of the drawings I will attach. I have a laser cutter ready to cut the parts.
A kit will cost $40 plus $5 shipping. It's made from aircraft grade ply. This is a direct purchase from the cutter.. Not through me.
Cutter is laserlizzard,.. paypal is [email protected]. Guys name is Jesse,.. he's cut 5 or 8 riggers for me so far.
uho,.. PDF is not supported here. I'll try for another format...
Or check out www.intlwaters.com under general stuff. http://www.intlwaters.com/index.php?showtopic=29861&hl=
If you have a car engine this would be an easy switch to boats if you can build a little. The parts are all tab locking so it goes together like a snap together model,, with glue that is...
