Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
PICCO .90 QUESTION
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
PICCO .90 QUESTION
Old 11-28-2009, 09:45 PM
moparhemi
Default PICCO .90 QUESTION
Does anybody know how much horsepower a picco .90 has..???? I have 2 picco .90s and one needs bearings and gaskets.... i need to know where to get these parts... i want to use one as a back up motor!!! if i can find the parts., thanks in advance dan
Old 11-28-2009, 11:45 PM
Ron Olson
Ron Olson's Avatar
Default RE: PICCO .90 QUESTION
Dan, it seems like they have a lot of power, in the 5-6 HP range. I've seen a few run, they're monsters when dialed in! Where to get parts for them, I honestly couldn't tell you.
Old 11-29-2009, 09:24 AM
chief3452
Dan, I believe you can buy bearings here http://www.bocabearings.com/main1.as...de&pg=2&mfr=19 For gaskets I use either paper grocery sacks or manilla office folders to obtain the required thickness. It's a pain to cut your own gaskets, but they work. Good luck, hope this helps.
Scott
Old 11-29-2009, 12:22 PM
advanced builder
advanced builder's Avatar
here you go http://www.teampicco.com/productshome.html
OFNA Racing
Address: 7 Vanderbilt, Irvine, CA 92618 USA
Phone: 949-586-2910
Fax: 949-583-9272
Web: www.ofna.com
Email: [email protected]
Old 11-29-2009, 09:16 PM
moparhemi
I went to team picco and saw the picco .90 but that is the new version I have the older version with the aluminum colored head. Team picco doe's not give you a horsepower rating. Ron I know you said 5 to 6 HP but can you be more persice? And would you know what prop to use? I have read alot of your posts and you really sound like you know what you are talking about and would appretiate any help. Thanks, Dan
Old 11-29-2009, 10:01 PM
moparhemi
About the prop I fergot to mention it is going in a 44" speedworld sonic 44. I finally found the website for the boat I have rcspeedworld.com they make a catamaran and a v hull which is mine called the sonic 44. It is intended for a gas engine but I am putting in the picco .90 Does it matter?
The only thing that I am haveing trouble with is the motor mounts. I made some out of aluminum but they dont look so hot and don't know if they will hold.  Doe's anybody know where to get motor mounts for a .90 size engine for 5" rails? Dan
Old 11-30-2009, 08:00 AM
f16man
The hp of the picco 90 really does not matter as it will have more power and rpm than almost any gaser engine , the picco was a very competitive engine in its day and still is.......
Old 11-30-2009, 06:08 PM
advanced builder
If you watch E-bay you could fine a older style. Watch what you buy, Look over for wear .mounting holes,carb Ask Questions, buy if you feel it's a deal. A price $ 80- $180 MAX if less $ GREAT
NOT a uncommon engine
Old 11-30-2009, 06:47 PM
HendricX
HendricX's Avatar
If it was already build for a gas-engine :
Buy the Zenoahmount that belonged to the existing drills.
Buy a foot of 3/8"x 3/8" bar stock , make bars that fit between the front and aft part of the Zenoah-mount ,
put the Picco on the bars , drill and tap , and there is your perfect 5" Nitro-mount.
If Zenoah-drills or the midsection-cut is not convenient , you can add 1/8"sheet to cover that.
When ordering metric-bearings for the Picco , ordering C3 fit , polyamide or phenolic retainer and RS shields is VITAL.
The inner shield has to come off , 2nd shield is always on the OUTside.
Old 12-02-2009, 11:27 AM
martno1fan
martno1fan's Avatar
Will a .90 be overkill for a 4 ft boat?,reason i ask is someone wants to put one in one of my 46" stepped vees.She handles modded zenoahs ok.
Mart
Old 12-02-2009, 01:08 PM
f16man
She'll fly with a 90 nitro.
Old 12-02-2009, 01:10 PM
martno1fan
martno1fan's Avatar
ORIGINAL: f16man
Yea thats what im worried about,i dont wanna give the guy the go ahead and it be too overpowered .I supose it depends which 90 he has in mind lol.
Mart
Old 12-03-2009, 01:20 PM
f16man
I belive he's talkin a picco , it would probly handel it pretty good with some throttle management.................
Old 12-13-2009, 12:54 PM
ronnie g
try www.intalwaters     RON G   I have 2 picco 90 in 45in scrabb   FASTTT !!!      im looking for ops 80 oiston and sleeve
Old 12-13-2009, 02:00 PM
rcguy1411
i had a picco p 80 in a 40 inch cat verry fast so i think that setup would work out verry well the only thing that may happen the boys with the zen s wont like being beat
