Dumas sport40 eagel build..
#51
OH
No the MRP is 24" i think??ok did a markup no the tailfins and wing with turbine tube too.. used poster board to see what it looks like.. not bad at all...
#52
TX
Actually the MRP's were 27 inches long and well made. Good thick ABS plastic. I had my cowl held in place with velcro on all four corners and its held up over many years.
That Eagle is looking good! Keep it up!
Its amazing that by adding wings to the boat & modding the cowl slightly how much it changes the appearance of the boat. I always thought the stockEagle "looked" sterile, now it looks like a hydroplane.
#54
OH
that what makes the unlimited look so good are the tailfins and wing..Ok I got the wood cut out for the tail fins and wing,plus made the fiberglass tubine exaust tube too..now it mount time and gluing the tubine tube on to the cowl..[8D]
#58
OH
ok got two eagle builds going on now..black one is my boyfriends..got mine epoxyed and primed today..still got some primming and sport pudding and blocking to do before paint..did do some modfication to the scoop opening like the 87 miss bud,should help draw in more air for cooling and helps pust the hot air out..
#59
I'm curious, why did you attach the turbine pipe to the cowl? Seems to me that leaving it a separate unit would have made the cowl easier to take off and put on
#60
OH
Ok how would you bolt that tubine tube down? plus if thats there how to you get the tune pipe off the bracket then?.. By having it one piece you can get the tube pipe off the bracket and take the bracket off too... Did this like how our RTR's are done...
#62
OH
No commit....like what I did quick and easy access to everything....
.. Dont know why you like doing things the compancated and difficult ways.[&:]....work smarter not harder...
#63
To each their own. Believe me, I don't do things the hard way, I do things to make my boats lighter, faster and last longer. You'll just have to wait until I build my Eagle to see what I do that's different from the way you and the RTR's manufacturers did. Part of the build won't even be the way Dumas designed it either. As I said, it's just the way I do things, so watch and learn.
#64
KS
Cant say there is a right or wrong way to do it BUT the tail on the back kind of makes it look like a hassle, to correct one thing said, the proboat has the turbine separate from the rest of the cowling, true it is more of a ring of fiberglass but it is still separate
#65
AZ
That is a very clean looking build. You are obviously a talented model maker.
Have you had this boat on the water, yet? Could you share how you attached the aft end of the cowling?
Having built and raced one of these to a state championship in the mid-90's, I will share a little of my experience. I am concerned that your center of balance using the Dumas setup will be too far aft. I ended up moving the engine forward and moving the radio box to the front of the boat. I am currently building a new Eagle-based boat with modifications to lighten it, change the attack angles on the front sponsons and move the engine even farther forward.
Ken
Ken
#66
TX
You know i just noticed that too in the pics above with the picco engine. is that where dumas shows having the engine mounted in the plans?
I noticed that all my Dumas hulls have the engine just forward of the sponsons transom.
#70
OH
I'd moved the radio box ahead wright against the fornt carnard/front spoiler notch out.. motor been moved up head 1" or so ahead... I have the header and tune pipes on .. the rudder and adjustable strut with flex tube been mounted..got some odds and ends to finished up before paint..need to put in water cooling lines rudder rod linkage and throtle linkage..took alittle break on it To work on my JAE.12 rigger kit.hull is done accept paint and mounting hard wear and motor&tune pipe and radio equipment.parts are subposed to hear by the end of the week... just got word the engine&tune pipe was sent out today with 2.4 radio system..
#71
AZ
ORIGINAL: jetpack
Short, upright wings like the Unlimited Lights carried would look good too on it. I thought of going with just those on mine. I do think keeping the back straight with some tail feathers can help at times.
Ken
#72
Hi Ken,
When I thought about mine, I thought back to the 1/2A control line landing gear and how they were designed. Music wire is amazing stuff.
I would probably make my wings out of balsa with a brass tube for the music wire post in the tops of each upright and then V down to a central pivot block to the transom.
A couple of small nylon screws to a tab on the bottom of each wing to the deck, or even making a tape ledge at the bottom and using hatch tape to hold it. It just has to be strong enough to take the breeze and a bit of pounding is all, only their own weight. The lighter you make them, the less it takes to hold them down. They are very "transparent" pieces to the wind.
You really don't want anything solidly mounted unless its totally indestructable from a five foot drop at 50mph into the water at any angle. That's a lot to ask for, so a break-away is what I would try like the 1/8th scale boats. HOWEVER, I haven't studied them much past finding out there's more than a few ways to accomplish that.
It will have a chance to break away without damage if done right and you might even luck out with it staying on the music wire with the dead boat.
I'll try and make a sketch and add it. I might have already seen the idea and remembering it this way.
To Misshydro, I drew the Eagle diagram in Dragon Green for you.
