Outrigger Help
I just got a 7.5 hawk outrigger kit and need to find a decent engine for it. would like to runn in the 60's. also i would like to know of some decent rudder and prop setups that arent top dollar but work good. any help would be greatly appreciated. This is my first outrigger build. ive built a crackerbox boat before so this should be somewhat similar, but any help is greatly appreciated.
RE: Outrigger Help
Also can i put in a .90 engine i know it only calls for a .46
RE: Outrigger Help
If you want the Hawk to be in the 70's, get ahold of Gary Preusse.. He designed the boat and can help you go fast.. Gary will be able to provide you all the information you need on the Hawk riggers. Phone - 630.279.2451
a 90 in a 45, not a chance... |
RE: Outrigger Help
i take it then about a .67 is most i can go. thanks for the phone number
RE: Outrigger Help
Before you put a larger motor in the boat, give Gary a call.. If you let him, he will chat your ear off.. You will find out the latest and greatest mods for that boat from Gary.
RE: Outrigger Help
I kind like the turnfin that's For sale @ Zippkits. You can use the .21 Zip hardware on the.45 Hawk. Just another option. If your a builder then you'll be back to Zippkits. When rigger fever sets-in The Octura strut & rudder are heavy. Liter is faster 60 MPH . Did you happen to look at the .21 Zippkits [World Record] driven by Martin Truax Jr On Joe's web site. The .67- .90 are being replaced by Gas. Why cost Nitro is not cheap any more. As is glow plugs. I can eat up a gallon in one afternoon. I used 3 gallons running my .21 & .12 all season long. .45 engines are not too bad.
RE: Outrigger Help
Al Hobbs should have some AA .45 engines in stock still. He is on IW. Do a search for that forum and look under Manufacturer's section. I can't give you a direct link on this forum. [:o] These engines should be fast!
RE: Outrigger Help
There was a 45 used on the same site. for/sale dept. i f money is tight.
RE: Outrigger Help
what about this type of drive? is adjustable better?
http://cgi.ebay.com/Adjustable-sting...item1e56c486a4 |
RE: Outrigger Help
ORIGINAL: markoverclock what about this type of drive? is adjustable better? http://cgi.ebay.com/Adjustable-sting...item1e56c486a4 |
RE: Outrigger Help
does anyone make a good light adjustable one?
RE: Outrigger Help
Check out the Speedmaster struts at www.rossisales.com
http://www.rossisales.com/SPDS-007-187-ROUND.jpg You could probably use the short brackets on your rigger. |
RE: Outrigger Help
Yes Craig that's a good one. I want a AA engine, but the $ made me think twice. But I'm assuming everyone is broke like me. At the moment. But I still want one. The green head.21 CMB that I got a deal on is my new girlfriend. The Zip.21 hull is still in the box. They go together fast I'm not worried
Craig, You have a package on the way. |
RE: Outrigger Help
Yes here is a pic http://www.rocketcityracing.com/prod...p?item_id=1681
RE: Outrigger Help
what is a good epoxy to use on the sponson and hull. I would like to put a thin coat on them for strength it. Iwill sand smooth apon drying. Thanks again for the help.
RE: Outrigger Help
ORIGINAL: markoverclock what is a good epoxy to use on the sponson and hull. I would like to put a thin coat on them for strength it. I will sand smooth apon drying. Thanks again for the help. www.masepoxies.com |
RE: Outrigger Help
ORIGINAL: advanced builder Yes Craig that's a good one. I want a AA engine, but the $ made me think twice. But I'm assuming everyone is broke like me. At the moment. But I still want one. The green head.21 CMB that I got a deal on is my new girlfriend. The Zip.21 hull is still in the box. They go together fast I'm not worried Craig, You have a package on the way. Neil, so what's in the package? |
RE: Outrigger Help
Which one do i get off of mas site. they have like a 100 differnent ones.lol.
also slow, med, or quick set? ORIGINAL: Blackout ORIGINAL: markoverclock what is a good epoxy to use on the sponson and hull. I would like to put a thin coat on them for strength it. Iwill sand smooth apon drying. Thanks again for the help. www.masepoxies.com |
RE: Outrigger Help
ORIGINAL: markoverclock Which one do i get off of mas site. they have like a 100 differnent ones.lol. also slow, med, or quick set? ORIGINAL: Blackout ORIGINAL: markoverclock what is a good epoxy to use on the sponson and hull. I would like to put a thin coat on them for strength it. I will sand smooth apon drying. Thanks again for the help. www.masepoxies.com http://www.masepoxies.com/products/d...ty-Epoxy-Resin |
RE: Outrigger Help
i called and talked to them i got this one http://www.masepoxies.com/public/ind...roductid=69480
smaller amounts and she said it will work just as good for what im using it for sence im not adding any fiberglass. Thanks for the help again. ORIGINAL: Blackout ORIGINAL: markoverclock Which one do i get off of mas site. they have like a 100 differnent ones.lol. also slow, med, or quick set? ORIGINAL: Blackout ORIGINAL: markoverclock what is a good epoxy to use on the sponson and hull. I would like to put a thin coat on them for strength it. Iwill sand smooth apon drying. Thanks again for the help. www.masepoxies.com http://www.masepoxies.com/products/d...ty-Epoxy-Resin |
RE: Outrigger Help
Yup, that's their FLAG epoxy. The FLAG epoxy is a little thicker than what I suggested, but will work fine.
RE: Outrigger Help
The mailman said 1 day Craig
I wanted to give you something in exchange for that fuel tank. No it's not a .45AA from Al markoverclock ,a credit card works well with epoxy you can save a pot by putting it the fridge. If you make too much. I like this http://klasskote.com/index.html |
RE: Outrigger Help
ORIGINAL: advanced builder The mailman said 1 day Craig I wanted to give you something in exchange for that fuel tank. No it's not a .45AA from Al markoverclock ,a credit card works well with epoxy you can save a pot by putting it the fridge. If you make too much. I like this http://klasskote.com/index.html It's going to be warmer this weekend. I think Karl and I will have to run his 3.3 T-maxx to get our nitro fix. :D We ran it 2 weeks ago in 25 degree weather and snow. The nitro engine ran real well, just get the engine started before the cold outside weather gets to the engine.... My basement shop is a steady 63 degrees during the winter. |
| All times are GMT -8. The time now is 10:57 PM. |
