Hinge Pin
How critical is a tight fit hinge pin or if it's a tad sloppy on an outboard? Thanks
Wholehog,
Don't fool with a loose mounting plate or the bracket attached to the engine...the steel pin probably is not the problem...with the R's OB engines turn it will cause excessive vibration...control becomes a problem ...if you are just fun running for your own pleasure once in a while, you can get away with it,but if you want to compete, or race....fix it !!!! Good boating, Jay |
What motor? What mount? Usually the Du-Bro mounts wear out over time but that part you can buy by itself if it's one of those. Rarely does the pin itself wear out.
Wholehog,
Another.. "maybe" ...I use wooden stands so I support the engine by fastening and adjustable bolt that can move up and down set on a cross piece between the 2 wooden sides of the stand...when the hull is at rest the bolt makes contact with the lower boot and takes the pressure of the engine as a whole as you exert pressure with your starter...it works! Jay |
Originally Posted by Ron Olson
(Post 11953170)
