K&B 3.5 Gold head con-rod
2 Attachment(s)
Okay I have a issue with replacing the con-rod in my 3.5 K&B outboard. I have tried the original bone style and the new style. There is some slop in the bushings on both ends. Any suggestions? Or is there supposed to be some movement and not snug?
http://www.rcuniverse.com/forum/atta...mentid=2135597http://www.rcuniverse.com/forum/atta...mentid=2135598 |
What crank do you have? 12mm or 13mm? Believe the 12mm has a "L" stamped at the end while the 13mm has "13" stamped. Old eyes, can't quite tell on the pics what is stamped.
Mark, it looks like a 13 on the counterweight. The pix are fuzzy but I could make that out.
Thanks Ron, that is what I thought. Just couldn't quite make it out on the small pic. There should be slight movement of "side to side" on both the crank and piston. But if there's a lot of "up / down" play, then there's issues. Have you tried another crank or wrist pin?
That ain't sloppy. I bought a new SS and the thing didn't have any bushings on the con-rod! It was no wonder that I could never get the thing to run right.
But when you opened it up to investigate, it voided the warranty!
Thanks for the info guys. I didn't try another crank or pin. Don't have any. I will see about the movement direction.
If you need another crank / pin, let me know. Think I have a few extra pins and possible a crank. I'm in the process of selling off my K&B 3.5 motors / parts.
ob nuts, thanks. I am still trying to figure it out. Not much time to look at it lately.
Okay guys, here is what I found out. It was a 13mm crank. After trying to reassemble the engine,the piston would not go into the sleeve again. I think the sleeve and piston need replaced. When using force to put back together they were both compromised.
Yea, force is not a good thing for these little motors. I'd have to check what is in my parts supply, but I may have a used or even a new p/s if you are interested. I'm slowly working away from K&B 3.5 motors.
How did you attempt to install the piston? I have never heard of a piston not going back a cylinder it came out of.......The cylinder is tapered, tighter at the top, piston goes in from the bottom.
Originally Posted by moparbarn
(Post 12171848)
Originally Posted by Ron Olson
(Post 12172040)
Trying to put the piston in with the sleeve installed presents a problem. You can't do that.
