RE: THE UNOFFICIAL SHOCKWAVE 36 THREAD
Me too. I leave for vacation in 3 weeks. I don't think my overhall of my V hull will be done in time. That leaves me with the SW36. I'm going to try a new glow plug, and pull the carb and make sure it is clean. I will also check my settings for the ????? time.
-Andrew It is strange, It ran great for 1- 1 1/2 tanks of fuel and BAM, has not run right ever sence. |
Did you check the coupler between the header and the pipe? that would do it.
Weathervane,
Have you tried sealing up the engine with some high temp silicone? Particularly around the carb. Also, have you checked to make sure the head bolts are on securely? |
It was terriable today i went down to where we keep our boat and the water was flat. I need a shaft to run my boat. this is killing me
Does anyone know where I can find a shockwave 36 rudder that is in stock.........Thanks Rick
ORIGINAL: weathervane Me too. I leave for vacation in 3 weeks. I don't think my overhall of my V hull will be done in time. That leaves me with the SW36. I'm going to try a new glow plug, and pull the carb and make sure it is clean. I will also check my settings for the ????? time. -Andrew It is strange, It ran great for 1- 1 1/2 tanks of fuel and BAM, has not run right ever sence. |
OK, The new glow plugs were delivered today. I'm going with the DYN2500. Now, acording to the Dynamite owner's manual this is the plug for this engine. I'm going to get a new bottel of fuel as well.
-Andrew I did check or try all of the above sugestions, no luck. |
ORIGINAL: weathervane OK, The new glow plugs were delivered today. I'm going with the DYN2500. Now, acording to the Dynamite owner's manual this is the plug for this engine. I'm going to get a new bottel of fuel as well. -Andrew I did check or try all of the above sugestions, no luck. |
Yes. I have looked the whole thing over. I pulled the engine and gave it a good going over. O rings are good, head bolts are tight, fitting in the exhaust pipe tight, all the fuel lines are good. I have done everything short of pulling the engine down. I WILL get it running. This thing has got me wanting some revenge. It will run.
-Andrew |
I hear you vane,,,,,
That thing should run good again and if you stick with it, it will. In my old but unseasoned thoughts, I think if it were a critical motor problem that you would have heat and/or multiple problems at once on the perfomance. I think I remember you saying it runs fine on the bench and dies in the water. You might check your drive shaft alignment. Hope you figure it out, cause these things make my hair rise at WOT. |
Hey Guys looong time since I posted, still have my SW and hope to get it out this summer. good to know this thread is still up and going. :D
IT'S ALIVE. I got it to run for more than 5 feet. My Shockwave 36 actually made a few laps around the pond today. It took a few attempts, after a carb change, needle settings, and just a lot of tinkering. I finally got it to run in the water. I put the stock carb back on and reset all the needles to factory specs. NO luck. I richened it up a 1/8 of a turn on the high speed needle, NO luck. I then richened the low speed needle by 1/8 of a turn, IT'S ALIVE. Well let's put it in some better light. It would run no matter where the needles were set, but when put into the water it would up and die. Now it will actually run laps. Cool. It has been so long sence I had it running I forgot how much fun this little thing is.
-Andrew |
congradulations on finally getting it running....dont forget to get some vids...
Thank you. It feels good to finaly get it right.
-Andrew |
That's good news. I plan on getting my wave out next week for the nephews. but worried about all the lilly pads I have to dodge.
Well i just ordered new 3 flexshafts from Aeromarine along with a few props. I should be good to go in a few days. I can't wait we have had such nice weather.
does anybody use the new starting system t - drive cause i would recomend it for people all you have to do is press the buttun and put on glowplug starter and it fired up no more pulling
....umm...ok....i used it when my SW36 was still nitro....(now brushless)
ive also heard it reeduces strain on the motor mounts... |
it does who found that out because my old engine broke of a bad piston so i replaced it
what is that gas nitro can you tell me when you log back on
my waterline broke i ordered the new one but now i cant get it it back threw the whole so it cant get to the engines did anybody else have that problem is so how did you get it back in. on shockwave 36
hi there. make sure the feul tank is sealing properly. check your feul filter. take carbb off. take it appart clean with compresed air. tighten head bolts. make sure presure nipple on header is locked with nut lock. my carbb settings- LS needle 3turns - HS needle 2 3/4. how is the compression? i hope my idees will help
no it for the water cooling i found a leak and replaced it but cnt get it threw the whole
If you're talking about the line going through the hull, you might have to drill it out a little larger. Some lines have a larger outside diameter on them. Sometimes putting an angle cut on the line will help it to go through.
I'm haeding to the lake in a few days. I want to try and get in a few more runs at the pond before I take it all of the way up their and it does not run.
-Andrew |
