RCU Forums
-   Speed - RC Nitro Boats (https://www.rcuniverse.com/forum/speed-rc-nitro-boats-117/)
-   -   difference between............... (https://www.rcuniverse.com/forum/speed-rc-nitro-boats-117/3725073-difference-between.html)
2916jr 01-03-2006 10:10 AM
2 & 3 blade props, what is faster?
Ron Olson 01-03-2006 12:03 PM
RE: difference between...............
One has only two blades and the other one has three!:D
OK, seriously. A 3-blade prop keeps at least one blade in the water at all times on a surface drive. Some prop sizes only come in only with only one or the other. What's more important is to find which prop the boat likes.
2916jr 01-03-2006 01:09 PM
and what is faster a surface drive, sub-surface drive, or a jet drive?
Ron Olson 01-03-2006 01:24 PM
Surface drive. It allows the prop to run half-way out of the water letting the engine rev higher and most of the time letting you turn a slightly larger prop in the process.
