How tight to tighten prop?
I have a Miss Bud withe the .15. I just purchased a y535 prop and was wondering how much to tighten the bolt. I went downstairs and relized:) Ive never had to replace one!![:-]
RE: How tight to tighten prop?
Just use a hand driver/screw driver with the scocket on it and hand tighten it.You can judge on the tighteness.I'd tighten it by,you cant wiggel the prop.[>:]
Thanks, adding mods at the moment-aluminum steering servo mount, aluminum water outlet, auto bailer, y535 prop, bru-line seals, and aluminum tiger drive.:D
I use a very small piece of fuel tubing to fit my prop shaft. Then I screw on the prop lock nut until it just makes contact with the fuel tubing. Finally one slight turn of about 1/4 is given to snug the lock nut up against the fuel tubing.
Ryan |
You might want to add a little piece between the collet and stuffing box. It will help to keep from loosing your whole driveline if the collet ever comes loose.
