WHAT SIZE MOTOR
hi question for all of you men and women in the know,, i have a 41 inch glass deep vee hull iam thinking on installing a HPI , 25 big block, i looked up the specs on it,, it hads 2.5 hp, think that would be enought?thanks mark
RE: WHAT SIZE MOTOR
IMO a 21 probably doesnt have the torque to get a 41" mono/deep v movin as good as it would with a 45.
then again if it was me i wouldnt put anything smaller then a .65/.67 in there. |
RE: WHAT SIZE MOTOR
Yup, it's definitely big for a .21 size engine. This size would easily handle a .45 and a .67 probably wouldn't be a stretch either. It would help to know which hull it is.
RE: WHAT SIZE MOTOR
I'm runnin a k&b 91 in my 40" prather,soon to be completed,(waiting on my pilots license :D),the name of this boat is ...........you guessed it.....overkill......[:-]
RE: WHAT SIZE MOTOR
I'd drop a .67 in that deep vee. They are used in the 1/8th scale hydros which range from 40" to 53" long, so as Piper chuck said "it's not a stretch".
RE: WHAT SIZE MOTOR
1 Attachment(s)
ill guess ill wait till i can find one i also have a dumas glass 31 inch deep vee the motor should be ok just air cooled.. iam also working on a jet stream i removed the 10 installed a aquacraft 15.. and removed the silly gear reduction. i also have two trazzas 2.5 one reg one and a R,might install one of those and be like a nitro v.well anyways it keeps me off the streets lol
RE: WHAT SIZE MOTOR
I have a 41" vee hull with an ASP .46 and it is too sluggish for me (mid 30's). Hoping to refit it with a .67 to squeeze some more speed out of it. Therefore I reckon you will be well and truley under powered with your intended setup.
