Outrigger Strut hieght
What is a good starting point for my FF.12's prop? Centerline of rear sponsons????
Mark |
RE: Outrigger Strut hieght
I am sure someone more knowledgable will chime in...but your rear sponsons are supposed to be out of the water. So, I think you set it up so that your tub is level to a surface...measure how high the botttom of the front sponsons are from the table...and center your strut barrel at the same height...
Sean |
ORIGINAL: hydroracer11g What is a good starting point for my FF.12's prop? Centerline of rear sponsons???? Mark |
Goodmorning All :)
Come on Mark lets see some more pics of your rigger build :) Please Paul |
As an added note, I tried what you are talking about, actually, with the top of the strut barrel even with the bottom of the rear sponsons. I got a lot of cavitation. Might be my setup, might be my prop...but I went an eighth of an inch deeper, and it worked better...then I went a little deeper still, and again, it seemed to work better.
This was not with a FF.12 though...it was with the lil rascal I was messing with. Sean |
with the boat sitting on the front sponsons the rear sponsons should be about 1/8" off the table with the boat sitting level.
The center line of your strut should be at that table level. so about 1/8" below the rear sponsons :) |
ORIGINAL: gooycheese Goodmorning All :) Come on Mark lets see some more pics of your rigger build :) Please Paul Mark |
