K&B 7.5 Outboard Question
I just pulled the head off of the engine to replace a broken bolt and I noticed that the prevoius owner was not running a head shim. Is this OK ?? The engine seems to run fine. Thanks</p> |
RE: K&B 7.5 Outboard Question
ORIGINAL: phil6019 I just pulled the head off of the engine to replace a broken bolt and I noticed that the prevoius owner was not running a head shim. Is this OK ?? The engine seems to run fine. Thanks</p> JD |
