RCU Forums
-   Speed - RC Nitro Boats (https://www.rcuniverse.com/forum/speed-rc-nitro-boats-117/)
-   -   help (https://www.rcuniverse.com/forum/speed-rc-nitro-boats-117/9182623-help.html)
icedude1989 10-18-2009 10:19 AM
help
hi guys,
i was taking my engine apart and as i came to the small screws underneath the pull start unit, one of them is stuck. how can i get it out without damaging the engine. the screw head is all rusted and now its kind of flat. can anyone help me out. thanks.
dave.
btw, just in case, my engine is a gxr28mr kyosho engine
thanks<br type="_moz" />
rcguy1411 10-18-2009 02:05 PM
RE: help
take a dremmel cut a grove in the head use wd 40 remove using a flat screwdriver if it had locktite on it use a little heat (make shure no wd 40 is on it or engine will go up in flames ) if its resessed try an ez out they work great
andybenton 10-18-2009 02:23 PM
RE: help
yes, cutting the flat groove in the top with the dremel is about your best bet
RickeyRockstar 10-19-2009 08:21 AM
RE: help
Try cutting a cross into the top head with a dremel cutting wheel then use some penetrating oil let dry then hit it with a little torch available at any Radio shack . let cool then take a screw driver and remove the screw, if all that doesn't work try a easy out drill bit
Rick in Denver
