MVD prop shaft strut bearing
I have noticed that my strutbearing has been moving out of the strut on a couple of runs until it rest against the dog. Is this normal or do I have to secure it in the strut somehow. Thanks.
RE: MVD prop shaft strut bearing
normal for this boat
Thanks for the info.
problem I had with the MVD, was that the bushing was pretty tight on the stub shaft, and loose in the strut. So I think the bearing was actually spinning with the stub shaft.
Sean |
Good info. I will look into it. I might need to clean up the shaft a bit. Thanks.
