STICK Brotherhood!!
#351
My Feedback: (21)
Found this link. You will need to set up a free account to download, but it's free.
https://www.*****ute.com/playlist/ZQaaThXnvrAf/
#352
#359
Scroll down to "Settings & Options"
Select "Edit Signature"
Make changes (Remember you can't go over 500 characters and spaces count)
Select "Save Signature" Optionally you can select "Preview Signature" if you want to see how it looks before saving.
Done!
#360
My Stik project has officially started. She is an old Model Tech Joss Stick ARC kit. I'm changing the tail to an Ultra Stick style tail and adding flaps. Going to mount a Super Tigre .90 glow engine on it.
Been 20 some odd years since I've been active in this hobby and this project has me excited to fly again. Going to have to break out a trainer to hone my flying skills first though.
I'll add photos as soon as I get the minimum post count up...
Chris
Chris
#361
Thrust angle question...
I'm building this Model Tech Joss Stick .60 size and the copy of the manual I have is missing the step regarding engine mounting. But the plans seem to indicate o degrees offset in both directions.
Does this seem right?
#362
#365
Great job, looks marvelous!
0-0 engine? Forget it.
0.5 down and 2.5 - 3.5 right. Depending on the engine/prop combination.
Pull to vertical, hands off.
Tweek right thrust until there is no deviation left or right.
Trust me, It's worth the effort.
#366
Chris
#367
Guys, I've had a H9 Ultra Stik 30cc, but broke it badly a couple months ago. I have two different engines that could power a replacement Stick. I have a DLE-20ra, and a 3W-56b2. I see that Texas RC has several "Dracstick" that could work with these engine sizes. I've never seen an airplane from Texas RC, so wondering if their airplanes are worth looking at. Thoughts?
Larry
Larry
#368
How big do yu want? This laser cutter has a 100" Stik short kit for under $100.
Big Stik (Model Builder magazine) | The Balsa Workbench
The plans can be downloaded here for local printing
Big_Stik_MB_100.pdf
Big_Stik_MB_100.pdf
#369
Not looking to build a Stick. Got a couple big builds on the bench already. Wondering the quality of Texas RC's airplanes. Looking for a big ARF.
Larry
Larry
#372
