Go Back  RCU Forums > RC Airplanes > Sport Flying
Reload this Page >
STICK Brotherhood!!
Sport Flying This forum is for those that like to fly just for the enjoyment of flying, and all the airplanes that help them. Discuss here the joys of flying and the airplanes that help you enjoy it.
STICK Brotherhood!!
Old 01-15-2015, 03:09 PM
  #51
jbarnes
Here are my two. AMR Stick 85 with a DLE111. AMR Twin Stick with twin DLE 55's. Both are regular fliers. If you want to build a stick then AMR is the only place to go. Easy build and fly great.
Jerry.
ID:	2063993   Click image for larger version
Name:	Twin Stick 002.JPG
Old 02-14-2015, 05:15 PM
  #52
ratshooter
Here is a pic of my scratch built Sweet Stik. I have owned 2 little stiks. a kit built sweet sik, my rememberance of a sweet stik when they were no longer available and I reentered RC and I also have a GP 40 stik. Yep, I like stiks.
Old 02-14-2015, 05:17 PM
  #53
ratshooter
I forgot one more stik. A SPAD Stik that is a fantastic flyer.
Old 02-14-2015, 06:24 PM
  #54
Super08
Super08's Avatar
Hard to beat a Stik for a tough fun flyer. Everybody should have at least one in their hanger.
Old 02-16-2015, 04:58 PM
  #55
RVator
I have a Ultra Stick 60 that I recovered and added to the elevator and rudder. Saito 100 with a 15x6 APC
Old 03-02-2015, 07:20 AM
  #56
warhwk
I installed a friends brand new OS 55AX and a 12-6 APC to my GP Big Stick 40 for break in. WOW!! I could barely hover it at 95% throttle with my OS 46 w\12-4. The 55 will hover it with ease at only 50% throttle and accelerate straight up. I may not give it back. I think he should use my 46 on his SIG Somthin' Extra until his skills catch up. Whatcha think?
Old 03-02-2015, 09:07 AM
  #57
Super08
Super08's Avatar
Switch to an APC 11x7 with the 55AX and hang on. It goes like stink.
Old 03-02-2015, 10:56 AM
  #58
warhwk
I bet!!!
Mach 3 fer shure
Old 05-18-2015, 04:49 PM
  #59
B.Day
B.Day's Avatar
Default GP Giant Big Stik
A few pictures of my 'new' to me, GP. Big Stik. Bought it used, it had not been crashed, but it needed a lots of work. I actually flew it the first time for a friend with an O.S. 160 on it and it was OK. But when I purchased it I wanted a gas motor.
After reading many post on these monsters I learned that a DLE 30 would be sufficient for power. I am familiar with this motor, as I have the same motor on a Goldberg Sukhoi, pictured elsewhere in another post on Goldberg models.
First was to do something about the tail wheel mount. I used a Dubro large bracket and ran the tail wheel shaft all the way up to the fin. I use this mount on all my planes and it works very good. Next and the biggest problem was to move the motor forward to prevent having to add so much weight as ballast. Typical short nose long tail plane. But if you look at the spec's is was built around the Fuji 32 which is a very heavy motor, like 10 oz's more that a DLE 30. I wound up moving motor ahead about 1 1/2" . Along with two 6v. batteries under the fuel tank I think I only had to add about 3-5 oz's. to the nose but that was better than the solid one pound with the 160.
Then the nose and the wheel pants changed the entire looks of the plane. The best part of it is that since it is such a long, nose to tail, plane it really flies great. Big wings help too. Ready to fly it checks out at 14 lb's. But the DLE 30 does not know it as it pulls it vertical as long as you want it to go in that direction.
Sorry about the upside down pict. I could not find a way to remove it.
ID:	2097027   Click image for larger version
ID:	2097028   Click image for larger version
ID:	2097029   Click image for larger version
ID:	2097030   Click image for larger version
Old 05-18-2015, 05:57 PM
  #60
Super08
Super08's Avatar
Very nicely done.
Old 05-19-2015, 12:43 PM
  #61
N410DC
You don't often see a Stik with a cowl. Looks nice!
Old 05-19-2015, 05:42 PM
  #62
B.Day
B.Day's Avatar
A Stik with a nose. A couple of years ago I built a 120 Texas RC Drastik with a OS 160 in it.
And before that I had built a Ultra Stick with a nose. It changes the entire appearance of the plane...
But the Drastik was a real bear, lot of power, it flew well. But not as good as this GP Big Giant Stik.
ID:	2097220   Click image for larger version
ID:	2097221   Click image for larger version
ID:	2097222   Click image for larger version
Old 06-21-2015, 01:12 AM
  #63
Lulabelle
My Feedback: (28)
I'm glad to see that someone started a Stik Brotherhood! When I first started flying, my friends had stiks of different types. At first, I thought they were ugly and I didn't want nothing to do with them. As time passed they grew on me and I haven't looked back since! Over the years I've owned and built several.
1. Midwest Little Stik
2. 2 Midwest Sweet Stiks
3. 3 Hangar 9 Ultra Stik 40's
4. GP Big Stik 40 (kit built)
5. GP Big Stik 40 ARF
6. GP BIG Stik 60 ARF
7. Hanger 9 Ultra Stik 120
8. 2 Mini Ultra Stik's
Old 08-07-2015, 10:25 AM
  #64
brick1
Amen!!!!
Old 11-13-2015, 03:54 AM
  #65
smkrcflyer
smkrcflyer's Avatar
I would like to build an electric stick from plans for a power 25 motor. What size stick would work with this motor?
Old 11-13-2015, 04:20 AM
  #66
Lulabelle
My Feedback: (28)
Hi smkrcflyer,
The plans for the Midwest das little stick .20 would work good for that. You could lighten it up in a few places to help keep the weight down and it would work just fine.
Good Luck!
Old 11-13-2015, 05:01 AM
  #67
smkrcflyer
smkrcflyer's Avatar
Do you know where I can get the plans and outlines for the die cut parts? I found some on ebay but not sure if there good.
Old 11-13-2015, 06:13 AM
  #68
Big Stikflyer
Big Stikflyer's Avatar
smkrcflyer, you can go to www.outerzone.co.uk
They have the plan your looking for. Do a search for "Das Little Stick". You can download the plans and take them to like a Kinko's to have them printed.
Enjoy and happy flying
Old 11-13-2015, 06:25 AM
  #69
smkrcflyer
smkrcflyer's Avatar
Found it, thanks.
Old 11-14-2015, 10:18 AM
  #70
JimmyZep
JimmyZep's Avatar
Im finishing up my Great Planes Big Stik 40 arf.
Taildragger with a Saito .62.
Had a couple 4 yrs ago, 1 crashed 1 sold when I quit.
Jimmy
Old 11-20-2015, 03:32 AM
  #71
smkrcflyer
smkrcflyer's Avatar
I got the planes printed out for the Midwest Das Little Stick. Does anyone have tracings of the die cut parts?
Old 12-25-2015, 08:56 AM
  #72
marksz1
STICKS RULE!!!!
H9 mini ultra stick
H9 40 stick with split ailerons set up for crow.
GP 40 stick with Saito 82
And now------
GP 60 stick with OS GGT 15 gas NO IGNITION---GLOW/GAS look it up runs better than glow!!!!
Also have (2) older sticks 40 size from Modeltech still in the boxes....woo hoo I do have other aircraft but keep going out with a stick as first choice!
Old 12-28-2015, 08:32 PM
  #73
marksz1
Sticks rule! No matter what else I build I always choose to fly my GP big sticks!
Old 01-11-2016, 06:33 PM
  #74
painlesstom
painlesstom's Avatar
I love STIKS!! I've learned on several 40 sized on brushless, and I absolutely love my Giant Stik. All my stiks have come from Value Hobby, can't beat the quality for the price and they fly very well. LOVE LOVE LOVE these planes!!
This was from yesterday, wind was kickin' and I was lovin' it.
https://www.youtube.com/watch?v=jD06_66aGG4 This video is from a while ago, I need to make a new video of it soon. She flies even better now!
https://www.youtube.com/watch?v=_acDA6997OA
Old 02-08-2016, 09:40 AM
  #75
silverwings
My Feedback: (21)
silverwings's Avatar
I just found this thread. Please count me in. I had a Midwest Super Sweet Stick as my second plane back in the 80's and loved it. After I got back into the hobby in the lat 90's, I've had several sticks. H9 Super Stick, Ultra Stick 120, multiple Ultra Stick 60's, GP Big Stick 60, and currently I have an Ultra Stick 120 Lite I purchased used that I am converting to a low wing.
I love sticks and will always have one.
I have a question that someone may be able to answer. I have plans from RCM that Jim Feldman drew for the LW (low wing) conversion article years ago. He listed Stan's Fibertech for the cowl, wheel pants and canopy. When Stan sold the business and retired, the new owners say they didn't get these molds and do not know who has them. Does anyone know where I could find them or if they even still exist? I really like the way they make the plane look and would like to reproduce it if possible. Any help would be greatly appreciated.
Rick
