Go Back  RCU Forums > RC Airplanes > Sport Flying
Goldberg Extra 300 set up help >
Sport Flying This forum is for those that like to fly just for the enjoyment of flying, and all the airplanes that help them. Discuss here the joys of flying and the airplanes that help you enjoy it.
Old 09-28-2017, 06:18 AM
Default Goldberg Extra 300 set up help
Hey folks I need some advice on setting up a goldberg extra 300. I have been out of the sport for a while and i am in the process of getting this bird back up.
These are the throws I have found on the net.
Ail low 3/8 high 5/8
elev low 5/16 high 7/16
rud low 5/8 high 1 3/16
cg 5 to 5 3/4
I have a saito 120 rudder servo in the tail and two servos for the elev in the tail.
I really need to know how to balance the plane canopy up or down.
Thanks Rickey
Old 09-30-2017, 04:03 PM
DGrant's Avatar
Alot of people balance a low-wing plane while inverted(canopy down)... I like to balance them all upright personally regardless of wing placement....
Knowing the Goldberg Extra is essentially a shoulder/mid-wing plane, I'm sure you'd be fine balancing it upright. No doubt in my mind.. as that's how I would do it. Good luck with that fine old classic.
Old 09-30-2017, 05:11 PM
Thanks for the reply, thats the conclusion I have came too also.
Old 09-30-2017, 06:56 PM
Thumbs up Here's a "Little" info
Fine airplane. Go to this link: http://www.rcuniverse.com/forum/kit-...tra-300-a.html and you will see EVERYTHING regarding the plane. It has 71 pages of info ! Be patient and cruise through them for your needs.
Right now I have 2 kits sitting patiently to be assembled, I just obtained an OS 1.08 for power for one, I am looking forward to the build this winter.
Old 10-05-2017, 09:13 AM
Moderator
FWIW, I had a similar plane (Sukhoi) wind up pretty far out of CG when I balanced it inverted. It turns out the wings were close enough to neutral that I couldn't get a good reading on it. I built a Vanessa CG rig and did a lot better job balancing it. It was easier to use too.
Old 10-05-2017, 10:46 AM
The one I had was balanced canopy down. Great flying model,wish I had it back.
Old 10-05-2017, 12:35 PM
cg 5 to 5 3/4
Thanks Rickey
Do a search right here on RCU in the Kit Builders forum as there is a very indepth and current thread there on the Carl Goldberg Extra 300L that is loaded with tons of valuable information and tips on building, trimming and flying the model.
Old 10-05-2017, 12:39 PM
Oh oh, just realized that Race 66 already gave you the link to the CG Extra.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
