Go Back  RCU Forums > RC Airplanes > Sport Flying
 Good Prop choices for OS 55AX? >
Sport Flying This forum is for those that like to fly just for the enjoyment of flying, and all the airplanes that help them. Discuss here the joys of flying and the airplanes that help you enjoy it.
Old 05-17-2007, 12:55 PM
Default Good Prop choices for OS 55AX?
Hi everybody, after reading up on engines for .40-.46 size aircraft, I've decided on the 55AX(seems like a great 2 stroke for 3D and sport flying). I would like to order 2 props with this engine, one for speed and one for 3D. From what I've read, this engine is able to swing a big prop for 3D, but I don't know which size to order. I'm thinking of pairing this with a Hangar 9 Twist 40 to practice some hovering, and I'd also like a speed prop for doing fast loops, rolls, etc. I currently own an 11x7 from my last engine. What 2 prop sizes would give me the most versatility with this engine? Thanks!
Old 05-17-2007, 04:13 PM
My Feedback: (10)
Default RE: Good Prop choices for OS 55AX?
I just installed an OS-55AX on a 5lb profile. New engine, APC 13x4, >12000rpm, ~6.3lbs of thrust. Works great and will only get better.
Old 05-18-2007, 07:58 PM
skull1971's Avatar
12X7 and go fast and 3D.
Old 07-26-2007, 10:09 AM
I also have a Twist, it's getting a 55 AX with a 13x4W APC. A friends Twist has the same engine with a 12x6 APC instead and flies very well, I just want to be a little different, I really like to fly slow right till it just about falls out of the sky, then power up. Anyways thats my input.
Wilki
Old 07-26-2007, 11:20 PM
ChuckW's Avatar
If you get a 13x4 APC for 3D, make sure it is the wide blade version. I messed up and ordered the wrong one last time.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
