Go Back  RCU Forums > RC Airplanes > Sport Flying
 LT-40 weight >
LT-40 weight
Sport Flying This forum is for those that like to fly just for the enjoyment of flying, and all the airplanes that help them. Discuss here the joys of flying and the airplanes that help you enjoy it.
LT-40 weight
Old 05-20-2007, 03:35 PM
Default LT-40 weight
Hey All,
I was wondering,how heavy is to heavy for a LT-40?The reason I'm asking is I never weighed my plane after I was done building it,and I noticed it felt heavier than my LT-40 arf,so I weighed both of them.The arf weighed in at seven pounds,and the kit built plane weighs in at just over eight pounds.The arf has a Saito FA-56 in it,and the kit plane has a Saito FA-82 for power.The kit plane has never been flown yet,it is slightly modified:almost no dihedral,it has flaps,and was built as a taildragger.It came out tail heavy,so I used a 4200mah sub "C" receiver pack instead of using lead to balance it.What do you guys think?
Thanks in advance Jim
Old 05-20-2007, 04:50 PM
Default RE: LT-40 weight
G'day Jim,
It will fly, it will have to fly faster, because of the increased wing loading, but it will fly.
It will have plenty of power, I hope you are using a 14x6, & have wheels large enough to allow ground clearance.
Even a brick will fly, with enough power, & NO, I'm not suggesting that your plane is a brick.
Old 05-20-2007, 05:01 PM
My Feedback: (8)
proptop's Avatar
It'll handle windy days better...heavier airplanes with a higher wing loading won't get knocked around as much.
You have more than enough power. As long as the wing center section is strong enough to handle G loads during manuvering, it should be o.k.
Give ya an example...
We had some lab guys that put between 6-7 lbs. of equipment in a Thunder Tiger "Tiger .60" trainer.
We had an O.S. .91FX on it, with a 32 oz. fuel tank...and it weighed in at 15 lbs. ready for take off...[X(]
I was their "stick man"...It flew o.k....went 97 m.p.h. (according to GPS ) and glided like a (streamlined ) brick...but 20-25 mph winds were no problem. (to be honest...winds were actually a good thing with all that weight, trying a STOL was tricky without wind )
Old 05-20-2007, 11:52 PM
Hey guys,
here's a couple pictures of the above mentioned planes.This is my first time trying to post pictures on this forum,I hope it works!
Thanks for your replies.
Jim Club Saito Member 509
ID:	688571   Click image for larger version
ID:	688572   Click image for larger version
ID:	688573   Click image for larger version
ID:	688574   Click image for larger version
ID:	688575   Click image for larger version
ID:	688576   Click image for larger version
ID:	688577   Click image for larger version
ID:	688579   Click image for larger version
ID:	688580   Click image for larger version
ID:	688581   Click image for larger version
Old 05-21-2007, 12:32 PM
carrellh's Avatar
I've always heard that the LT-40 kit builds pretty light, so I'm a little surprised about yours.
I have a Great Planes PT-60. It's about the same size as the LT-40 and it weighs about 8 pounds. My plane is modified to be a tail dragger, no dihedral, dual aileron servos, etc. My plane seems to glide forever, so I doubt that you'll have any negative issues with yours.
Old 05-21-2007, 06:08 PM
Yeah I guess I used a little to much epoxy in the fuselage around the engine and fuel compartments.Whats really odd is it ended up tail heavy!All I added to the rear fuse was a tail wheel and some tri stock to the fin for strength.I also glassed the whole wing center section.Oh well it'll probably fly fine. I just hope the landing gear holds up to our rough field and my dumb thumbs!I hope to fly her this weekend(long weekend)so I'll let you guys know it goes.I know its just a trainer but these LT's are the most fun for me.I have four of them well three and a Seniorita.Simple to fly and simple to repair.
Thanks for your comments.
Jim, Club Saito Member #509
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
