Go Back  RCU Forums > RC Airplanes > Sport Flying
 3-blade prop on a 4*star 60 >
Sport Flying This forum is for those that like to fly just for the enjoyment of flying, and all the airplanes that help them. Discuss here the joys of flying and the airplanes that help you enjoy it.
Old 11-01-2007, 03:20 PM
Default 3-blade prop on a 4*star 60
I have a 4*60 and I just bought a o.s. 91 4 stroke for it. I would like to know if any body has ran a 3 bladed prop on this set-up? Gene
Old 11-02-2007, 11:43 AM
Deadeye's Avatar
Default RE: 3-blade prop on a 4*star 60
I'm sure they have. A 14X8 or 14X6 2 blade sounds about right for the 91. For 3 blade you drop an inch in length, so you need a 13X8 or 13X6 3 blade, and a spinner to match. Good luck!
Old 11-02-2007, 01:30 PM
My Feedback: (18)
Gringo Flyer's Avatar
MA recomends when going from a 2 blade to 3 blade prop a 1 inch drop in diameter and 1inch increase in pitch.
Old 11-02-2007, 01:47 PM
My Feedback: (14)
Lomcevak Duck's Avatar
A 14x4 or 13x6 two blade runs well on the .91 Surpass, so maybe 13x4 three blade might work well? Try a few sizes and see. You'll be able to tell if it's more prop than your engine is happy turning.
Old 11-02-2007, 08:41 PM
I don't know about the 4 star but I had a Cessna with a 91 that I also flew off floats and I ended up using a 12 x 6 3 bladed. At first I did it because I needed more clearance between the floats and from the water, it worked great. Then I started flying it off grass and it felt so good that I just kept the 12 x 6 on it. I used Graupner props.
One thing to keep in mind is that a certain prop may be good on one plane but not on another almost like it, you need to experment.
ENJOY !!! RED
Old 11-03-2007, 09:33 AM
My Feedback: (18)
This is off the MA website.
4. Converting from a 2-Blade to a 3-Blade Propeller
To convert form 2 blades to 3 blades you want to decrease the total blade area and
increase the angle of attack (or pitch) to overcome the increased drag of the third blade.
The general rule is to DECREASE propeller diameter by 1-2”, and INCREASE by 1-2”
the propeller pitch. It is all right to keep the same pitch when going from 2 blade to 3,
however you will not want to decrease pitch.
Old 12-12-2007, 03:38 PM
FlyingGreg's Avatar
I know this thread is a little old, but I have a 13x8 three blade with an OS 91FS on a Goldberg Ultimate right now. Before that, I had it on a 4*60, just because it looks cool. Performance suffered marginally, but still would do great knife edge and flat spins. Get a spinner from Dave Brown products--they will cut it for whatever prop you want for an extra 5 bucks.
Old 12-18-2007, 10:30 PM
OzMo's Avatar
A three bladed prop will let you go a little longer before you need to mow the field again
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
