Go Back  RCU Forums > RC Airplanes > Sport Flying
 Does anyone have experience with the new Evolution props yet? >
Sport Flying This forum is for those that like to fly just for the enjoyment of flying, and all the airplanes that help them. Discuss here the joys of flying and the airplanes that help you enjoy it.
Old 11-14-2007, 02:33 PM
Default Does anyone have experience with the new Evolution props yet?
They look real nice, and the price is in line with other sport props. They also seem reasonably stiff (more so than MA and on a par with APC). On the other hand, they seem a little on the heavy side. One customer at the LHS where I work p/t said his needed quite a bit of balancing...
Anybody else actually flying with them?
Old 11-15-2007, 03:48 PM
sowega flyer's Avatar
Default RE: Does anyone have experience with the new Evolution props yet?
I'm flying a 13x7 Evolution prop. Unfortunately, I can't really give you any comparison notes about it as it went on a brand new ASP .80 fourstroke on a brand new WM Rambler 45. I haven't tried any other brand of prop in that size on that plane. Mine didn't take a whole lot to balance, and it has been very durable. My rambler loves to nose over at the sod farm where I fly. I would buy another one.
Old 11-22-2007, 08:11 PM
Just picked up a couple of the evolution 11-5's for my arrow trainer. (which comes with an evolution engine) Neither one would fit; holes to small. Figured I'd put them on my new OS46AX, again the holes were to small. I'm just getting back into this hobby after several years, so I guess i'm kind of a newbe. However, I don't think having to force screw on props is the correct procedure.
Old 11-22-2007, 10:55 PM
broke_n_bummin's Avatar
I've been using a 15X6 and 16X6 on a 1.08 and have had about the same results as an APC. The 11X6 that I've been using seems to be right up there as well. I didn't have to ballance much on the 15 and 16" props. The 11X6 I didn't have to ballance at all.
The Evolution wood props are a different story...
Old 11-23-2007, 08:52 AM
ORIGINAL: harmsway
You need to get one of these.
http://www3.towerhobbies.com/cgi-bin...&I=LXK248&P=ML
You will be able to open it up to the correct size.
Old 11-23-2007, 02:13 PM
Thanx pkevinb
Old 12-14-2007, 03:20 PM
My Feedback: (21)
bassfisher's Avatar
Harmsway - almost every prop that you buy will need to be reamed out to fit the propellor shaft.
Old 02-21-2008, 07:32 PM
Ed_Moorman's Avatar
A few years ago, when eastern European engine became more easily available, the prop manufacturers quietly changed the standard prop hole from 1/4" to 6 mm. 6 mm is slightly smaller, so these days most all props need to be reamed for 1/4".
Old 02-21-2008, 09:21 PM
acarter's Avatar
ORIGINAL: harmsway
Thanx pkevinb
Or a if you have a drill press that would work better. At least it does for me!
Austin
Old 06-28-2008, 05:49 AM
Banned
My Feedback: (12)
I just used a 14x8 Black Evolution prop on a Saito 100 and it seems to be on par w/ the rpm expectations of an APC.
About 9250 rpm running 20/20 at sea level.
It did need to be balanced quite a bit by using 2 strips of white paint double coats on the light side and a sanding on the heavy side.
Looks better than the grey APC - just as heavy and same flex at WOT.
About $8.99 as of 6/08 as opposed to 12 or $13 for the APC.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
