endless mountains R/C fly-in montrose pa 1aug09
1 Attachment(s)
RE: endless mountains R/C fly-in montrose pa 1aug09
1 Attachment(s)
1 Attachment(s)
1 Attachment(s)
1 Attachment(s)
Great Pics !!! Do you Fly ? Bob |
1 Attachment(s)
1 Attachment(s)
1 Attachment(s)
1 Attachment(s)
Hi bob,
yes i fly! but i have not figured out how to fly and take pic's. so not alot of pictures of mine. here's some first is a Flop Tite Hollywood Zero wt 8.5# power O.S. Max 1.2 4c also flown with ASP 80, K&B .65, Magnum 90 4C, Super Tigre S-61K ABC (round head), and Super tigre S-90 (round head) rretracts are spring air's and covered in momokote controls are AERTRF with the throtle servo mounted to the engine mount from day one. somewhere around 400 flights second is a Great Planes Ultra sport 60 wt 6.25# powered by Super Tigre S-61K ABC (round Head) started life blue green and yellow and on trike gear. had the EZ hinges fail on elevator and Aileron in the late 90 si i recovered in momokote then to Blue and yellow. controls are AERT. well over 600 flight maybe in the 800 range third is Model Tech. 90 size P-51D ARC over wt at 12.5# out of the box so it to is covered in monokote, first covering was flat momokote but it could not take the UV from the flightline and shattered on one wing panel in flight. powered by a Magnum 1.20 4C with Rhom-Air retracts and Robo struts, controls are AERTRF. some where just shy of 200 flights. fourth is a Dynaflight PT-19 powered by a Zenoha G38 and wt of 13.5# and flys Great! covering is sig Koveral Dope with alunimum powder and laquer paint and century Jet struts made spacificly for this plane at that wt. controls are AERT. 60 flights second row first plane is my oldest and best flyer. Platt Focke Wulf 190D-9 with a Super Tigre G-90k ABC for power and Rhom Air retracts, every year I consider mounting OLEO's but it is just to old. covered with silk span ans dope and painted with Hobby poxy it wt's in a 9.75#. Controls are AERTRF with about 300 flights second row second plane is my GP Fokker Dr1 powered by a Super Tigre S-90 Wt does not matter! Controls are AERT I pinked all the seams to keep them from pulling and it has worked very well. this plane gives me fits, it is impossible to low pass because it acts like my three year old grand son, you can start in on the path but no amount of guidence is going to make it take the path you want it on, you can only hope for close second row third plane is an IMP Macchi 202 powered by a ZDZ 40 and pulled by a 20X12 prop. tipping the scales at 17# it is going to give the FW some competition for best flyer. retracts Are IMP struts are IMP wing is covered with flat coverite and paint is from low's. controls are AERTRF and only 6 flights. second row fourth plane is an Evergreen P-51D ARF tipping the scales at 8# last year it needed a recove so I switched it to a B reteracts are Century Jet Powered by a beat up old surpass 2 O.S. Max 1.2 4c. controls are AERTRF covered with Monokote and about 250 flights. |
1 Attachment(s)
ORIGINAL: dignlivn Great Pics !!! Do you Fly ? Bob This is his good ear and Dr-I from last year. |
Infact, I would love to get the info on each of these planes but if it comes down to flying or gathering that info.. I'm flying! if there is anyone out there willing to gether that info. you know where to get ahold of me. I'll pay you the same i get payed (HaHa). or if you pm me with your info., if you see your plane in one of my posts. i can add it, the more detailed the better. just remember I need a hot link and the post # to reduce my time. thanks.
Joe |
that looks like fun, the Fun Fly's or Flyins here where i live most of them anyhow will be C restricted or listed as IMAA.
