S-90K Internal Parts confusion ???
Baxter, I will be rebuilding a S-90K, and I'm getting conflicting info on Parts, can you clear it up for me ??
in-short, do I use the G90 Piston, Cylinder Liner and Connecting Rod in the S-90K ??
BTW, Towers show the 2 Engines use the same Liner, different Pistons, but says nothing about the Rod,,
http://www3.towerhobbies.com/cgi-bin...r%3C%2FB%3E+90
and can you tell me where I can buy parts, Towers is out of almost everything I need ??
thanks Baxter !!!
Jim
thanks Baxter !!!
Jim
RE: S-90K Internal Parts confusion ???
There are differences in the parts.
S90K and G90 have the following in common: piston ring, cylinder liner, piston pin retainer, and the wrist pin. They each have their own piston and connecting rods.
If the parts are not available from Tower, they're not available almost anywhere else. They pull from the same warehouse we do.
