SuperTigre Engines Support Ask Bill Baxter your questions regarding the SuperTigre line of engines.
3000 and 3250
Old 07-18-2011, 03:50 PM
WhiteRook
My Feedback: (38)
Default 3000 and 3250
i have two itallion version SUPERtigres , one 3250 , one 3000.
Will the carb from the 3250 fit the 3000 ?
Old 07-20-2011, 06:19 AM
Bax
Default RE: 3000 and 3250
Yes, but you may need to check to see if the S-3000 has the shim inside the mounting boss. Depending upon when the S-3000 was made, it may have had the smaller carb and had a shim to "neck down" the intake boss.
Old 07-20-2011, 12:15 PM
WhiteRook
My Feedback: (38)
so if you take the shim out of the 3000 , the 3250 carb will fit? the 3000 i own does have the early carb.
