G-51 idle screw adjustment
PA
How many turns out would be a good starting point for the IDLE MIXTURE SCREW? I'm sure that I must be way off and want to get it back to the factory, or your recomended setting. Thanks
RE: G-51 idle screw adjustment
The easiest way to reset the idle mixure screw is to pull the carb off the engine and look through the bottom of the carb throat. With the throttle fully open, you'll see a slot cut in the brass spraybar with a silvered colored idle needle partially blocking it. You should adjust the idle needle so that it reaches half way across the opening at full throttle.
David Wolf, Senior Product Support Supervisor
Great Planes Product Support
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Support Phone: 217 398-8970
Email: [email protected]
