S90 reverse running?
I have heard a few people say that on the old "S" series engines can be made to run in reverse. If you remove the front case, turn it counterclockwise 90 degrees (facing the motor) and rebolt it on, that the timing will now be for reverse running. Figured you would have the definitive answer on this. Thanks
