SuperTigre Engines Support Ask Bill Baxter your questions regarding the SuperTigre line of engines.
Weight of a 51 vs. 45 .
Old 09-18-2009, 11:40 AM
The Gopher
Default Weight of a 51 vs. 45 .
Swapped a 51 for a 45 in my Bipe now I'm tail heavy . Is the 51 lighter?
Old 09-21-2009, 09:38 AM
Bax
Default RE: Weight of a 51 vs. 45 .
There is less than a 1/2-ounce difference, so unless you've installed a different exhaust system, something else is the difficulty.
Old 09-21-2009, 12:57 PM
The Gopher
Thanks Bax, I did pull 1/2 oz of wieght off the tail and used a heavier prop nut to balance out.. After a nasty tail heavy flight
