RCU Forums
-   SuperTigre Engines Support (https://www.rcuniverse.com/forum/supertigre-engines-support-163/)
-   -   ST G-4500 Throttle Arm (https://www.rcuniverse.com/forum/supertigre-engines-support-163/11655304-st-g-4500-throttle-arm.html)
Red Baron Mike 10-12-2018 05:48 PM
1 Attachment(s)
Anyone have a throttle arm they would sell that will work on a Super Tigre G-4500?
ST22333236
Throttle Arm New Style
By SUPER TIGER PARTS
Attachment 2262205
do335a 10-13-2018 08:02 AM
That would be be very easy to replicate by silver soldering a small brass strip for the lever to a suitable size wheel collar. The set screw in the collar will hold it to the shaft to which it is clamped with that pinch bolt. Holes drilled in the brass strip will allow for the attachment of the throttle pushrod.
Might take about 5 minutes to make the substitute.
Red Baron Mike 10-13-2018 09:06 AM
Thanks....Was hoping to find the correct part.
