RCU Forums
-   SuperTigre Engines Support (https://www.rcuniverse.com/forum/supertigre-engines-support-163/)
-   -   Fuel? (https://www.rcuniverse.com/forum/supertigre-engines-support-163/1262941-fuel.html)
Mitty 11-09-2003 01:40 AM
Fuel?
Hi there.
Me again with another question.
I heared that european engines are designed to run low nitro precentage.What can you guys recommend,nitromethane-wise?What fues i should use and how much oil do i have to have for supertigre .61?
Thanks alot.
Mitty
Bax 11-10-2003 10:58 AM
RE: Fuel?
[img][/img]You can run just about any of the common model fuels through your Supertigre engine. They'll run well on 0% to 15% Nitro. Low-nitro fuels are not required. For your .61, the fuel should contain at least 18% oil or so. A blend with castor oil is strongly-recommended.
